metinvr
PI4 and 4K video player
Wed Oct 02, 2019 1:55 pm
Dear All,
I tried to play 4K video x264 or x265 by using omxplayer, but couldnt play. Which OS and which player is suitable for this process. Also tried buster. Could you please help about this subject.
Best regards,
6by9
Re: PI4 and 4K video player
Wed Oct 02, 2019 2:03 pm
Libreelec
dickon
Wed Oct 02, 2019 2:14 pm
And H.265 only. H.264 is limited to 2K.
gkreidl
Wed Oct 02, 2019 2:24 pm
On Raspbian: Kodi
Minimal Kiosk Browser (kweb)
metinvr
Sun Oct 06, 2019 12:50 pm
I know kodi or libreelec could be used but is there any support for buster to play 4K video x264 or x265? In future is there any plan for it?
dickon
Sun Oct 06, 2019 1:04 pm
Kodi is an application. It runs on Buster, and should be able to play 4K H.265 video. 4K H.264 is not possible, as the hardware can't do it.
I'd like a commandline H.265 player like omxplayer, but I've no idea if one is in the works.
dom
Mon Oct 07, 2019 5:58 pm
We have VLC supporting 4K H.265 when running fullscreen both from the command line and from X.
I'm not sure if the updated version is out yet, but it should be imminent.
dickon
Mon Oct 07, 2019 6:13 pm
Over the weekend, I attempted to build popcornmix's ffmpeg fork and link it against mplayer, but it didn't work. Clearly no acceleration was going on, and the output was interestingly corrupt on the screen.
(Edit:) I should probably add that this wasn't much of a surprise. If it was that easy, someone would have done it by now.
dom
Tue Oct 08, 2019 11:04 am
We've had a guy spend several weeks on this.
The problem is that video decode is not the only bottleneck.
If you hw decode the video and then software resize, convert YUV->RGB and blend in subtitles/osd you'll still find HD videos still don't play well.
The solution needs hw support for the decode, resize, convert and blend.
And the path taken is different when running VLC from console or desktop.
It's different when running fullscreen or windowed.
It's different when running with legacy GL driver and fkms.
So it wasn't a simple job.
gkreidl
Sun Oct 13, 2019 9:24 am
Imminent? It isn't in the repository yet.
yougz
Sun Oct 13, 2019 4:32 pm
Personally I am disappointed for the moment performance in reading 4K videos on the Pi 4 (Libreelec and Raspbian) I expected better on that side.
I get better results with TV box under Amlogic S905X2 for example.
Do you think that will improve a lot on that side?
Thank you
dickon
Sun Oct 27, 2019 9:14 pm
Any news on this? Currently, I get
vlc is already the newest version (3.0.8-0+deb10u1+rpt1).
and have had for some months.
dom
Mon Oct 28, 2019 12:07 pm
We spotted a couple of issues in testing before planned release last week.
4K hevc playback in a window was not showing video, which we now have a fix for.
There is a memory leak on seeking that is being investigated.
dickon
Mon Oct 28, 2019 12:11 pm
Thanks for the update.
arnoldchan
Wed Nov 06, 2019 3:22 am
I have tried 4k video playback from both VLC command line and from X, both failed. Did I miss anything?
My VLC version 3.0.8
Arnold
gkreidl
Wed Nov 06, 2019 7:33 am
Arnold
Yes. This post: https://www.raspberrypi.org/forums/post ... #pr1558233
photoartk
Thu Mar 05, 2020 12:51 am
I am new to RP 4. I have a fully updated Raspberrian. I tried vlc with the H.265 video (Windows says it HEVC). Have an HDMI to a 4k Sony TV and set Raspberrian to 4k. This is what I get. Can anyone help?
Art Krumrey (AKA photoartk)
pi@raspberrypi4:~/Videos $ dir
AAMC_IT_Compliance.wmv
BerryWyrwaChristmasTrees2013.wmv
BluesBrothersReview200802.mp4
Finley\ 20200217\ Swim\ Wheels\ on\ the\ Bus\ 265.mp4
Finley\ 20200217\ Swim\ Wheels\ on\ the\ Bus.mp4
Finley\ First\ Christmas\ 2019.mp4
KramersPond200607.mp4
pi@raspberrypi4:~/Videos $ vlc "Finley 20200217 Swim Wheels on the Bus 265.mp4"
VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
[00811e10] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00796b58] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
qt5ct: D-Bus system tray: no
[b2044528] mmal_avcodec decoder: Looking for HEVC decoder 'hevc'
DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory
Failed to create scanout resource
mmal: mmal_vc_port_info_set: failed to set port info (2:0): EINVAL
mmal: mmal_vc_port_set_format: mmal_vc_port_info_set failed 0x8e662020 (EINVAL)
[8e66e8c0] mmal_codec filter error: Failed to commit format for input port vc.ril.isp:in:0(SAND) (status=3 EINVAL)
mmal: mmal_vc_port_set_format: mmal_vc_port_info_set failed 0x8e698e20 (EINVAL)
[8e6626b0] mmal_codec filter error: Failed to commit format for input port vc.ril.isp:in:0(SAND) (status=3 EINVAL)
[8e65a458] chain filter error: Too high level of recursion (3)
[8e6626b0] main filter error: Failed to create video converter
[8e65cef8] chain filter error: Too high level of recursion (3)
[8e65f118] chain filter error: Too high level of recursion (3)
[8e66e8c0] main filter error: Failed to create video converter
[8e65ddd0] mmal_codec filter error: Failed to commit format for input port vc.ril.isp:in:0(SAND) (status=3 EINVAL)
[8e65ddd0] main filter error: Failed to create video converter
[8e6626b0] chain filter error: Too high level of recursion (3)
[b20c0428] main vout display error: Failed to create video converter
[b20c0428] main vout display error: Failed to adapt decoder format to display
[b2702b60] main video output error: video output creation failed
[b2044528] main decoder error: failed to create video output
[b2044528] mmal_avcodec decoder error: Failed to update format
[b2044528] main decoder error: buffer deadlock prevented
Auto101
Thu May 28, 2020 7:57 pm
Would the new 8GB version of pi 4 be any use to play 4k videos?
6by9
Fri May 29, 2020 11:09 am
Seeing as the lower memory versions of the Pi4 can play 4k HEVC, why would the 8GB version be any different?
Performance is rarely determined by memory these days (within reason).
