Pi Zero vs Zero W - power consumption (or A+?)
Posted: Sun Sep 29, 2019 4:05 pm
Hi everyone,
I hope my question won’t make you mock me, I know it might sound a bit silly
My need from the device:
1. VPN server (any) [Or as STS]
2. Less power consumption as possible
3. Low heat (but it’s not the most important)
I currently have Pi zero W, very satisfied! Brilliant device.
Will Pi Zero (not w) use low power consumption if I connect it to the network using micro-USB to Ethernet adapter?
Did someone tested it?
Or else someone is aware for a device with ethernet only and is lower consumer than Pi ZeroW?
Thanks in advance
Thanks in advance
