Milliways
Gap in Raspbian images
Wed Sep 25, 2019 8:02 am
I was just looking at my Raspbian and there seemed to be a 4MB gap between the end of the boot partition and the start of the root, confirmed in gparted.
Thinking this may be an artefact of the image copying utilities I use I checked against a downloaded Raspbian image (2019-07-10-raspbian-buster-lite) which has the same gap.
Is there any reason for the gap? It is not big enough to worry about or worth the effort to modify.
Paeryn
Re: Gap in Raspbian images
Wed Sep 25, 2019 8:40 am
Generally it's down to optimisations for the SD card like trying to make sure the two partitions are in different erase blocks. This reduces the wear and hopefully limits the erase/write block operations on one partition from affecting another.
Kendek
Wed Sep 25, 2019 8:41 am
It's because the first, FAT32 boot partition is larger exactly one sector than the ideal.
256 MiB (524288s) proper last sector = 8192 + 256 * 1024 * 1024 / 512 - 1 = 532479
If the last sector is 532480 (so 256 MiB + 512 bytes), then the first sector for the second partition is 540672.
parted /dev/mmcblk0
unit s
print
Milliways
Wed Sep 25, 2019 9:45 am
I understand why partitions should be aligned on an Erase Block Boundary.
The boot partition is aligned with a 4MB Erase Block Boundary, its size is a multiple of 4MB , so is the root partition aligned with a 4MB Erase Block Boundary, but it would if it started at 532480 immediately following the boot partition.
Kendek
Wed Sep 25, 2019 9:49 am
Yes, but currently the first partition ends in sector 532480, so the next partition is started at 264 MiB.
Milliways
Wed Sep 25, 2019 11:11 am
That just changes the focus of the question; why is the boot partition size set incorrectly?
ShiftPlusOne
Wed Sep 25, 2019 11:18 am
If you would like to fix it, a PR can be sent here https://github.com/RPi-Distro/pi-gen/bl ... run.sh#L26
Kendek
Wed Sep 25, 2019 12:42 pm
16 - ROUNDED_ROOT_SECTOR=$(((BOOT_SIZE + ROUND_SIZE) / ROUND_SIZE * ROUND_SIZE / 512 + 8192))
16 + ROUNDED_ROOT_SECTOR=$(((BOOT_SIZE + ROUND_SIZE) / 512))
26 - +$((BOOT_SIZE / 512))
26 + +$((BOOT_SIZE / 512 - 1))
But there is already a fix:
https://github.com/RPi-Distro/pi-gen/pull/285
ShiftPlusOne
Wed Sep 25, 2019 12:47 pm
Ah, I knew it rang a bell. Thank you.
ejolson
Thu Sep 26, 2019 3:43 am
Has anyone checked whether the gap is full of zeros or whether it contains a secret message?
Thu Sep 26, 2019 6:34 am
Like the BBC Micro OS ROM that had an area of memory mapped I/O ports over part of it and that (normally inaccessible) area of the ROM had the names of all the developers in it?
Or the time I was given a floppy disk from an Acorn developer and looked at the unused space on it and found fragments of text files that contained details about the original ARM design plans.
