erebus^
Best way to make RPi report it's public IP
Tue Sep 24, 2019 12:46 pm
Heya!
I have a RPi with your usual home setup. ATM I rent a DNS name from a provider, but I'm not sure if it's something I really need.
So I've been looking for a way to make the RPi regularly send me it's public IP, by mail or something.
I only need it so I personally can log on to it via SSH.
Is there a way to do this? Is there a command line to find your public IP address at all?
Thank you :)
Andyroo
Re: Best way to make RPi report it's public IP
Tue Sep 24, 2019 12:57 pm
Have a look at https://www.ipify.org/
Returns IPv4 and IPv6 in json for you.
tpyo kingg
Tue Sep 24, 2019 12:59 pm
Another way is to subscribe to a dynamic DNS service. It might be part of your current DNS subscription, or it may be an add on, o ryou might need to do it completely separately.
Once you have dynamic DNS, you can install and configure the package ddclient. That will phone home to the service and update your address in their register. The end result is that you can then SSH to a host name and it will automatically go to your current address.
erebus^
Tue Sep 24, 2019 1:04 pm
Oh, very nice, thanks! This helps me a lot.
I can't really think of any other way of reporting it back than email. Or maybe a chat-bot of some kind...
erebus^
Tue Sep 24, 2019 1:06 pm
Thaaaat is what I have right now, I believe. And yeah, it works great, but it also costs money. I might keep it anyway, but I'd thought it be fun to dive in to some alternative ways of solving this...
B.Goode
Tue Sep 24, 2019 1:12 pm
Let me be your imagination..
Twitter
MQTT
A GUI app that displays the information in a window on your Desktop.
An additional display (maybe just a 16-character LCD) to present that IP address.
tpyo kingg
Tue Sep 24, 2019 1:14 pm
There are also free-of-charge dynamic DNS options. The service noip.com has one. There are lists of them around. You'll have to read the terms of service to see if that one or anything like that is acceptable. At best you have to renew the free trial every month. It might be least work to keep paying like you have.
If you are just looking to find the IP address before leaving the Raspberry Pi, then you might just have it look up its external address and show that on an LCD or e-paper display. I've done that with an Inky PHat. It's ok as long as you remember to check before leaving and, depending on the ISP, it might not change too often.
erebus^
Tue Sep 24, 2019 1:24 pm
Hmmmm, a free DDNS might be all I need actually. Any recommendations? Is https://duckdns.org reliable?
Andyroo
Tue Sep 24, 2019 1:48 pm
I’ve been using https://www.dynu.com for a long time.
No issues with response time from outside and it’s simple enough to update.
I have one minor issue where it reports back that the IP address has changed but it has not maybe once a day but that’s not an issue as it still works.
This is the basic script I use (well it’s the latest one I can get hold of on my iPad :lol: )
#!/usr/bin/python3
import logging
import sys
from subprocess import PIPE, run
if len(sys.argv) > 1:
    if sys.argv[1].upper() == 'DEBUG':
        log_level = logging.DEBUG
    elif sys.argv[1].upper() == 'INFO':
        log_level = logging.INFO
    else:
else:
logging.basicConfig(filename='/home/pi/IP-change.log',level=log_level, datefmt='%Y/%m/%d %H:%M:%S', format='%(asctime)s %(message)s')
pwd = "https://api.dynu.com/nic/update?hostname=example.com&password=longcomplexstringgoeshere"
update = run(['curl', pwd], stdout=PIPE, stderr=PIPE)
logging.debug('Program executed under debug logging')
logging.debug('Return code = ' + str(update.returncode))
logging.debug('Return Data = ' + update.stdout.decode())
if update.returncode > 0:
    logging.warning('Curl failed with code ' + str(update.returncode))
if update.stdout.decode() != 'nochg':
    logging.info('IP address change - ' + update.stdout.decode())
This runs from a cron job with info or debug as the parameter depending on the amount of logging I’m interested in.
Edit: code tags now corrected...
Kendek
Tue Sep 24, 2019 1:59 pm
wget -qO- ifconfig.co
curl ifconfig.co
or if you have an IPv6 WAN address too, but you need the IPv4:
wget -qO- v4.ifconfig.co
curl v4.ifconfig.co
spock
Tue Sep 24, 2019 4:22 pm
if you buy a domain you could also use cloudflare. they have an api that can be used to update your ip.
jbudd
Tue Sep 24, 2019 5:11 pm
I use duckdns. It's very simple to set up and not too hard to update it with an HTTP request when your public IP changes. (I use a Node-Red flow to update it automatically)
My only slight niggle with it is you can't login directly to duckdns, you have to use your google, reddit, twitter etc ID.
Tue Sep 24, 2019 5:43 pm
I use
#!/bin/bash
IPv4=$(dig +short myip.opendns.com \@resolver1.opendns.com | grep -v -e '^$' || echo "0.0.0.0")
This is a doctor free zone.
Roken
Tue Sep 24, 2019 6:52 pm
curl ifconfig.me
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
