Mon Sep 23, 2019 8:55 am
godspeed146 wrote: ↑Sun Sep 22, 2019 7:48 pm
DougieLawson wrote: ↑Sun Dec 29, 2013 6:24 pm
config.txt is simply a plain text file.
You can edit it on your RPi with sudo nano /boot/config.txt
You can shutdown your RPi and copy a good version to it using Windows.
It's read by the firmware, but only to provide some override parms for things like the GPU memory split and HDMI graphics settings.
The override parms for the Linux kernel are in /boot/cmdline.txt (and the same rules for editing it apply).
What I do is copy the current c*.txt file to c*.txt~ before editing, then I can undo changes that don't work or don't have the desired effects. Some time later I'll clean up the ~ versions. I hope that rpi-update doesn't just trample over my version.
When trying to delete the config file from the sd card in windows, I get an error saying the file is corrupt and it doesn't get deleted. Basically I have to install the image every time it gets corrupted(has been happening a lot for the past few days)
You have necro'd a 6 year old thread - best to start a new thread.
However, this sounds like a SD card on the way out.
