Raspberry pi 3B+ under voltage issue.
Posted: Sat Sep 21, 2019 3:45 pm
by Tonmoy Paul
Raspberry Pi 3B+.
When I turn it on, It shows "Under voltage detected!"
But I use original power supply which provide 5volt, 2.5A.
But It still showing this type of message. I also have 2 more problems.
1. It is showing inverted color and red color raining issue in the booting screen.
2. I cant play any audio/video content. Whenever I play Display sucks. but When I remove mouse and keyboard It turns on but dont play anything.
Help me out. I'm using my pi for 6 days only. It was all okay when I boot it first. But those problems starts occurring since second day.
Please anyone help me out.
Re: Raspberry pi 3B+ under voltage issue.
Posted: Sat Sep 21, 2019 3:50 pm
by bomblord
Sounds like either your pi or your power supply is fried. Also the potential is there that an accessory or something plugged into your pi is pulling too much power.
First remove all peripherals and try a fresh boot with a new install of Raspbian to rule out any potential external/software issues. Then try replacing the power supply. If the issue persists after all that your pi is the issue and you're going to need a new one.
