pcmanbob
posting or replies blocked [SOLVED]
Fri Sep 20, 2019 12:41 pm
Attempting to post a reply to this thread https://www.raspberrypi.org/forums/view ... 3&t=252146
results in a sorry you have been blocked page.
Re: posting or replies blocked
Fri Sep 20, 2019 12:46 pm
There is an artificial stupidity snooping all the posts and blocking things apparently.
Who know what words or phrases might send it off into a tantrum. Or maybe it did not like the look of your IP address.
pcmanbob
Fri Sep 20, 2019 12:50 pm
Don't think its my IP as it let me post a new thread ( this one ) and a simple reply of " test " to the tread I wanted to post to,
rebooted my pc just in case there was a problem with my browser going to try again with the reply I wanted to make.
pcmanbob
Fri Sep 20, 2019 1:04 pm
So after some more testing I can post simple text but any attempt to post code even a simple print statement in code tags results in the post being blocked with the above error.
yet it works ok in this thread
print ("test")
Edit ...
So I finally got it to post all I changed was was all references to phValue to phvalue in the code :?
ShiftPlusOne
Fri Sep 20, 2019 1:08 pm
I've passed it on to the web team.
pcmanbob
Fri Sep 20, 2019 1:22 pm
thanks ShiftPlusOne. please see my edit , repeated here too.
ShiftPlusOne
Fri Sep 20, 2019 1:30 pm
They've looked into it and reduced the sensitivity on the check that triggers this to reduce false positives.
Fri Sep 20, 2019 1:34 pm
ShitPlusOne:
At some point, the check will be no longer necessary.
I can't figure what you mean by that.
Presumably you are not expecting SPAMMERs and other garbage stop arriving soon.
pcmanbob
Fri Sep 20, 2019 1:35 pm
Thanks ShiftPlusOne
May be I did not need to change the variable name after all , guess they changed things while I was attempting to post.
grega
Site Admin
Fri Sep 20, 2019 1:37 pm
We have various firewall rulesets in place because, well, this is a forum and they're historically not the most secure pieces of software :|
The relevant rules have been tweaked.
Sorry for the faff, as ever with these things there are going to be false-positives when attempting to prevent the possible actions of a malicious minority.
ShiftPlusOne
Fri Sep 20, 2019 1:39 pm
Removed that comment to avoid confusion, although that will probably only add to it.
ejolson
Fri Sep 20, 2019 4:50 pm
Why would the variable name phValue be off limits but phvalue fine?
Is there a well-known malware that measures hydrogen-ion concentrations?
Was the filtering the result of a more general 🐪-case detector?
pcmanbob
Re: posting or replies blocked [SOLVED]
Fri Sep 20, 2019 5:03 pm
That was the only change I made to the code I was posting , but it could be that changes to the filter happened while I was changing the code and the variable name change had nothing to do with it.
Guess we will never know.
tpyo kingg
Fri Sep 20, 2019 5:07 pm
I was blocked also this afternoon. In that case it looked like including the full system path to the SSH daemon's configuration file inside a comment triggered the false positive. Cloudflare is undesirable, IMHO.
