oicfar
Slurm: After reboot nodes are in state = down
Thu Sep 19, 2019 8:51 pm
I'm working with slurm-wlm 18.08.5-2 on Raspberry Pi Cluster:
- 1 Pi 4 as manager
- 4 Pi 4 nodes
This work fine. But after every restart of the nodes I get this
[email protected]:~ $ sinfo
PARTITION   AVAIL  TIMELIMIT  NODES  STATE NODELIST
devcluster*    up   infinite      4   down pi-4-node-[1-4]
state. Than I can call
sudo scontrol update NodeName=<node_name> State=RESUME
for every node and sometimes are all nodes idle and some down
cluster @pi-manager:~ $ sinfo
devcluster*    up   infinite      2   idle pi-4-node-[1-4]
Status to all nodes
[email protected]:~ $ scontrol show nodes
NodeName=pi-4-node-1 Arch=armv7l CoresPerSocket=1
   CPUAlloc=0 CPUTot=4 CPULoad=0.24
   AvailableFeatures=(null)
   ActiveFeatures=(null)
   Gres=(null)
   NodeAddr=192.168.178.141 NodeHostName=pi-4-node-1 Version=18.08
   OS=Linux 4.19.66-v7l+ #1253 SMP Thu Aug 15 12:02:08 BST 2019
   RealMemory=1 AllocMem=0 FreeMem=3687 Sockets=4 Boards=1
   State=IDLE ThreadsPerCore=1 TmpDisk=0 Weight=1 Owner=N/A MCS_label=N/A
   Partitions=devcluster
   BootTime=2019-09-19T17:38:58 SlurmdStartTime=2019-09-19T00:26:36
   CfgTRES=cpu=4,mem=1M,billing=4
   AllocTRES=
   CapWatts=n/a
   CurrentWatts=0 LowestJoules=0 ConsumedJoules=0
   ExtSensorsJoules=n/s ExtSensorsWatts=0 ExtSensorsTemp=n/s
NodeName=pi-4-node-2 Arch=armv7l CoresPerSocket=1
   CPUAlloc=0 CPUTot=4 CPULoad=0.06
   Gres=(null)
   NodeAddr=192.168.178.142 NodeHostName=pi-4-node-2 Version=18.08
   BootTime=2019-09-19T17:38:57 SlurmdStartTime=2019-09-19T00:26:49
   AllocTRES=
   CapWatts=n/a
NodeName=pi-4-node-3 Arch=armv7l CoresPerSocket=1
   CPUAlloc=0 CPUTot=4 CPULoad=0.02
   Gres=(null)
   NodeAddr=192.168.178.143 NodeHostName=pi-4-node-3 Version=18.08
   RealMemory=1 AllocMem=0 FreeMem=3676 Sockets=4 Boards=1
   State=DOWN ThreadsPerCore=1 TmpDisk=0 Weight=1 Owner=N/A MCS_label=N/A
   BootTime=2019-09-19T17:38:55 SlurmdStartTime=2019-09-19T00:26:45
   AllocTRES=
   CapWatts=n/a
   Reason=Node unexpectedly rebooted [[email protected]:39:32]
NodeName=pi-4-node-4 Arch=armv7l CoresPerSocket=1
   Gres=(null)
   NodeAddr=192.168.178.144 NodeHostName=pi-4-node-4 Version=18.08
   BootTime=2019-09-19T17:38:52 SlurmdStartTime=2019-09-19T00:26:47
   AllocTRES=
   CapWatts=n/a
   Reason=Node unexpectedly rebooted [[email protected]:39:30]
NodeName=pi-manager Arch=armv7l CoresPerSocket=1
   CPUAlloc=0 CPUTot=4 CPULoad=0.00
   Gres=(null)
   NodeAddr=192.168.178.140 NodeHostName=pi-manager Version=18.08
   RealMemory=1 AllocMem=0 FreeMem=3446 Sockets=4 Boards=1
   BootTime=2019-09-19T17:35:48 SlurmdStartTime=2019-09-19T08:10:51
   AllocTRES=
   CapWatts=n/a
Nodes which are down, the Reason is:
What is the problem that after reboot the nodes are in state = down?
ejolson
Re: Slurm: After reboot nodes are in state = down
Fri Sep 20, 2019 4:10 am
- 1 Pi 4 as manager
- 4 Pi 4 nodes
Status to all nodes
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
I don't know, but it happens for me too. Having the nodes start in the down state has never bothered me enough to investigate. It seems easy to switch their state to up again. If you figure out a more graceful way of shutting a cluster down, it would be nice to hear about it.
oicfar
Sun Sep 22, 2019 6:48 pm
- 1 Pi 4 as manager
- 4 Pi 4 nodes
Status to all nodes
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
I understand the flow now.
https://bugs.schedmd.com/show_bug.cgi?id=1602#c2
But I don't know, why the nodes are after start in the wrong state.
On my Slurm cluster I installed the Docer Swarm. This works perfect. When I shutdown one one, than the node is marked as down in the Swarm. When I reboot the node, after some seconds is the node visible in the Docker Swarm.
I have now a script for setting the right state for the Slurm nodes. But it should work per default correct.
oicfar
Sun Sep 22, 2019 7:47 pm
- 1 Pi 4 as manager
- 4 Pi 4 nodes
Status to all nodes
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
   Gres=(null)
   AllocTRES=
   CapWatts=n/a
I don't find any solution. I this case I added to the root crontab:
sudo su
crontab -e
this line
@reboot /usr/local/bin/resume_node.sh
and this is the content of the resume_node.sh script
#!/bin/bash
scontrol -dd show node $HOSTNAME | grep "Node unexpectedly rebooted" && sudo scontrol update NodeName=$HOSTNAME State=RESUME
