Goker91
Installing Visual Studio Code
Tue Sep 17, 2019 11:10 pm
Hi All,
Does anyone know how to install Visual Studio Code on Raspian?
I was trying to install it, but with no luck.
I am using Raspberry Pi 4, and still no luck installing it.
Thanks!
W. H. Heydt
Re: Installing Visual Studio Code
Tue Sep 17, 2019 11:23 pm
If I'm not mistaken, Visual Studio is a Microsoft product for MS Windows. As such, it is written for a different operating system that run on a different--and incompatible--hardware architecture.
Andyroo
Tue Sep 17, 2019 11:44 pm
Have you seen the Headmelted install at https://code.headmelted.com/? I’ve not tried it under Buster.
You HAVE TO BE AT A SUPER USER shell and not use sudo, so make sure you use
sudo -s
first.
Note this is built on updates from Microsoft so you may have the odd glitch till M/S solves it :lol:
The other option is to use the ssh remote debug from another machine https://www.hanselman.com/blog/VisualSt ... utter.aspx
jcyr
Wed Sep 18, 2019 12:35 am
Not quite, MS supports .deb packages for both 32 and 64 bit versions of Debian Linux on Arm. Unfortunately these are tailored for stretch and haven't yet been updated for buster.
It's um...uh...well it's kinda like...and it's got a bit of...
asavah
Wed Sep 18, 2019 12:55 am
Visual Studio Code != Visual Studio
jcyr
Wed Sep 18, 2019 1:06 am
Sure, just making sure the OP wasn't given the impression that installing Visual Studio Code was impossible on a Pi.
Wed Sep 18, 2019 4:00 am
W. H. Heydt,
You are mistaken.
VS Code is by MS but it is an Open Source product. Written in Javascript/Typescript using the Electron open source library. As such it can be built to run on Windows, Mac and Linux. Both x86 and ARM.
Electron is a application framework created by GitHub. It uses Google's Chrome renderer and V8 Javascript engine so as to be able to create desktop applications with browser technology, HTML, CSS, JS. It also uses Node.js to run the application side of the code that requires access to the local file system, networking and such that JS in the browser cannot see.
VS Code is my editor/IDE of choice now a days, for it's speed, simplicity, cross-platform and open source nature.
markkuk
Wed Sep 18, 2019 4:19 am
The latest version doesn't work. Version 1.29 works but it's almost a year behind the current upstream version (1.38).
Wed Sep 18, 2019 4:36 am
Does anyone know who headmelted is?
It's a huge security problem to suggest people download and install random binaries from unknown, untrusted web sites.
I'm not suggesting headmelted has bad intent but I do urge people to be careful.
markkuk
Wed Sep 18, 2019 4:49 am
GitHub believes he's this guy: https://github.com/headmelted
hippy
Wed Sep 18, 2019 10:13 am
Have a read of - https://www.raspberrypi.org/forums/view ... p?t=191342
I have generally settled on using Steve Desmond's VS Code version 1.28.2 build for the Pi which 'just works' without faffing about -
cd ~
wget https://github.com/stevedesmond-ca/vscode-arm/releases/download/1.28.2/vscode-1.28.2.deb
sudo apt install ./vscode-1.28.2.deb
Note that later versions intended for a PI may not work and Visual Studio Code has gone to 64-bit only so the very latest versions won't run on Raspbian.
mt08
Tue Oct 15, 2019 7:06 am
I could build codium which is based on VSCode 1.39.1, and generate .deb file using VSCodium script. ( https://github.com/VSCodium/vscodium )
Although I've just built and not used well, I share it. It should work on Raspbian buster for RPi 2/3/4.
deb file has been split in two, since github supports up to 25MB.
Please download 2 files, and concatenate them, then 'apt install'.
curl -LO https://github.com/mt08xx/files/raw/master/codium_1.39.1-1571119600_armhf.deb.xaa
curl -LO https://github.com/mt08xx/files/raw/master/codium_1.39.1-1571119600_armhf.deb.xab
cat codium*.deb.* > codium_1.39.1-1571119600_armhf.deb
sudo apt install ./codium_1.39.1-1571119600_armhf.deb
nrushforth
Tue Nov 26, 2019 10:41 pm
Hi
I have installed VSCode on Raspbian Buster with the .net core 3.0 SDK.
I can compile and run the C# code with no issues, however I am not able to debug directly (locally) on the RPI.
Does anyone know how to do this? When I try to do it I get an error that armv71 is not supported for debugging.
Help?
mike632t
Wed Dec 04, 2019 1:07 pm
Did you install from the MS source ? I've tried getting it to compile several times on a Pi4 (4G), I've overcome the heap overflow problem, but having got it to compile I get a SEG fault when I try running it.
