david_1234
free some RAM
Mon Sep 16, 2019 8:45 am
hello ,
I have notice that my PI is sometime unavailable to reach by ssh , and the screen is freeze
this is what I get when I use "free -h " command
free -h
              total        used        free      shared  buff/cache   available
Mem:           926M        657M         24M        216M        244M         14M
Swap:           99M         99M          0B
I can see I have a probelm
is there anything I can do ?
mayeb to up the swap to 1G?
the SD card is 16GB , and I only use ~7
Thanks ,
Re: free some RAM
Mon Sep 16, 2019 8:50 am
So, what is using up all the memory? And which Pi?
Adding swap will probably help a bit depending on the use case.
david_1234
Re: free some RAM
Mon Sep 16, 2019 8:55 am
a java\node-JS application that run on the browser ?
this is what I have running on my PI3
Re: free some RAM
Mon Sep 16, 2019 9:03 am
Browser + Java == large memory demand. Swap would probably be the a good bet, or using a small SSD, or best would be upgrading to Pi4 with more RAM.
david_1234
Re: free some RAM
Mon Sep 16, 2019 9:14 am
I'm waitng for PI4 to arrive - it will be next week ~
just to be sure
this is how I increase the SWAP ?
sudo nano /etc/dphys-swapfile
change it to 1024?
jahboater
Re: free some RAM
Mon Sep 16, 2019 9:32 am
just to be sure
change it to 1024?
Yes
sudo sed -i 's/^CONF_SWAPSIZE=[0-9]*$/CONF_SWAPSIZE=1024/' /etc/dphys-swapfile
sudo /etc/init.d/dphys-swapfile restart
david_1234
Re: free some RAM
Mon Sep 16, 2019 9:47 am
I did it the old way
but
Thank you!
Fidelius
Re: free some RAM
Mon Sep 16, 2019 9:54 am
zram usually helps, too, in particular for machines with not-so-much RAM.
If I remember right, it's been part of previous versions of Raspbian, and it's still in Debian-based Ubuntu, so depending on which Raspbian version you use, you could activate it via:
sudo apt install zram-config
To see what it is doing you can use:
swapon --show
The new Debian-10 based Raspbian-10 unfortunately misses this package (does anybody know why?), so there we would have to download Ubuntu's package from kernel.org first…
wget https://mirrors.kernel.org/ubuntu/pool/universe/z/zram-config/zram-config_0.5_all.deb
…and then install it:
dpkg --install zram-config_0.5_all.deb
david_1234
Re: free some RAM
Mon Sep 16, 2019 10:01 am
OK
and what does this do?
after download I need to change some setting ?
Thanks,
Fidelius
Re: free some RAM
Mon Sep 16, 2019 12:38 pm
My linked Wikipedia page writes:
When used for swap, zram … allows Linux to make more efficient use of RAM, since the operating system can then hold more pages of memory in the compressed swap than if the same amount of RAM had been used as application memory or disk cache. This is particularly effective on machines that do not have much memory.
No, by installing the package zram-config (with "dpkg --install" in the case of download, or with "apt" in case of being already in the apt-repository), a zram device is set up with a size up to half of your RAM size and used as swap device. I find this 50% setting to work well on my 1 GByte Pi3 and 4 GByte Pi4.
You can see the zram swap usuage with either the mentioned command:
swapon --show
…or by using:
zramctl
Both commands also show that zram distributes its swap RAM to all CPU cores in order to maximize the speed of de-/compression in the swap RAM.
With the latter command you can furthermore fine-tune its usage. Please see its man-page: man zramctl.
david_1234
Re: free some RAM
Mon Sep 16, 2019 1:26 pm
OK ,
I have download like you told me
and this is what I get
pi@raspberrypi:~ $ swapon --show
NAME      TYPE  SIZE   USED PRIO
/var/swap file 1024M 101.5M   -2
what does -2 mean?
when I try to run
zramctl
I get nothing
Fidelius
Re: free some RAM
Mon Sep 16, 2019 1:52 pm
Have you installed the downloaded ".deb" file?
Like:
Maybe a re-boot is neccessary afterwards.
david_1234
Re: free some RAM
Wed Sep 18, 2019 7:12 am
Yes , a reboot did the trick
now I get this :
free -h
Mem:           926M        582M         79M         80M        264M        211M
Swap:          1.5G        590M        896M
zramctl
NAME       ALGORITHM DISKSIZE   DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 lzo         115.8M 112.4M 23.6M 25.6M       4 [SWAP]
/dev/zram1 lzo         115.8M 112.3M 23.7M 25.6M       4 [SWAP]
/dev/zram2 lzo         115.8M 112.3M 23.4M 25.3M       4 [SWAP]
/dev/zram3 lzo         115.8M 112.7M 23.7M 25.6M       4 [SWAP]
can you expalin if what I see is good?
and does it mean?
Thanks ,
Fidelius
Re: free some RAM
Wed Sep 18, 2019 7:30 am
That looks fine.
To see why zram helps, in particular users of slow SD-cards, please see my above Wikiepedia article or various other Linux articles, like for example Aarch-Linux's short explanation here. I couldn't explain it any better: Improving performance
The zram kernel module (previously called compcache) provides a compressed block device in RAM. If you use it as swap device, the RAM can hold much more information but uses more CPU. Still, it is much quicker than swapping to a hard drive. If a system often falls back to swap, this could improve responsiveness. Using zram is also a good way to reduce disk read/write cycles due to swap on SSDs.
david_1234
Re: free some RAM
Wed Sep 18, 2019 7:35 am
Thanks .
I hope it will do the job until I start to woel with the PI4
ctparental
Re: free some RAM
Sun Dec 01, 2019 2:44 pm
for raspbian10/debian10 why not use zram-tools which is found in official repositories rather than zram-config ?
https://packages.debian.org/buster/zram-tools
bluenote
Re: free some RAM
Mon Jan 06, 2020 10:03 pm
Anything to report on trying both options if you have?
