david_1234
can I create my own PI card?
Sun Sep 15, 2019 10:16 am
Hello ,
Wanted to know
I have an application that run on PI - but the cpu is around 75% all the time
because it's a big apllication and we have try to reduce - nothing.
and all the code is java +python according to the pi pins (reading I\Os, using pi packages etc..)
so is there a way to build my own card ,sp it will be like PI3 but much stronger? better CPU and RAM?
Thanks ,
joan
Re: can I create my own PI card?
Sun Sep 15, 2019 10:30 am
Highly unlikely unless you can afford to pay for several thousand units. If your application is not Pi specific there are plenty of other boards you could use.
drgeoff
Sun Sep 15, 2019 10:39 am
Use a compiled language instead of Java and Python.
HawaiianPi
Sun Sep 15, 2019 10:47 am
... it will be like PI3 but much stronger? better CPU and RAM?
There already is one. It's called the Pi4: https://www.raspberrypi.org/products/ra ... 4-model-b/
And that would help as well...
Sun Sep 15, 2019 11:14 am
Hello ,
Wanted to know
Thanks ,
Pi4? More speed, more ram.
david_1234
Sun Sep 15, 2019 12:00 pm
I agrre with this
but we found that there are some application work better and easier to write\debug\work sometime in Java and sometime in Python.
and the application use many of the PI pins , we prefere to stay with this .
I will try the PI4
Thanks ,
W. H. Heydt
Sun Sep 15, 2019 4:38 pm
That is, trivially obviously, your choice. The reason for the suggestion to use a compiled language is that you were asking how to reduce CPU load. Clearly, reduced CPU load is not a priority for your project. Or--at least--not a higher priority than using the languages you've chosen.
wildfire
Sun Sep 15, 2019 4:55 pm
I'm maybe missing something here?
Your CPU is running at 75%, what's the problem?
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
Imperf3kt
Sun Sep 15, 2019 10:40 pm
If Python is important to your application why not make use of Cython?
55:55:44:44:4C
52:4C:52:42:41
