Raspberry PI 4 and battery
Is there a battery that will run a Raspberry PI 4? Thanks.
Re: Raspberry PI 4 and battery
Certainly. What other constraints do you have, such as "is it reasonably portable"?
Or:W. H. Heydt wrote: ↑Sat Sep 14, 2019 4:44 pmCertainly. What other constraints do you have, such as "is it reasonably portable"?
"How long will it last?"
"Is additional hardware required?"
"Is it prone to catching fire?"
"Can it be recharged? How?"
without any other info on the use-case....
I've always suggested using "8D batteries" in the past.....
needs buck converters though.... but will definitely last longer.....
Some people be like:
Perhaps try the Pijuice hat
