The Power Circuit in Pi Zero vs Pi Zero W
Posted: Fri Sep 13, 2019 7:02 am
by spaceman5
Hi all
If you look at the Raspberry Pi Zero and Zero W boards,
focusing on the Power Circuit on the right side,
There is a slight difference..
Raspbeery Pi Zero:
Raspbeery Pi Zero W:
Most of the components are identical, in type and even position,
but look at the Pi Zero (first picture) where it says "L1",
and look at the Pi Zero W (second picture) in the same position..
The component looks different.
Is it the same component (Inductor) in both, just in a different casing,
or a different component?
Hopefully someone got to check it out..
Thank you
Re: The Power Circuit in Pi Zero vs Pi Zero W
Posted: Fri Sep 13, 2019 8:05 am
by laurent
Probably due to power requirement difference between Zero and Zero W, they had to use a stronger inductor.
Posted: Fri Sep 13, 2019 8:15 am
by spaceman5
Hi laurent
Thank you for your answer.
Both boards work on 5v,
Do you know what is the required Current in the Zero vs the Zero W?
And also, do you know how much Current each of them can provide to a USB Device that is connected to the Host port?
(is there maybe a datasheet for each Raspberry Pi?)
Posted: Fri Sep 13, 2019 8:23 am
by drgeoff
Hi laurent
There is no explicit current limiter on the USB port on either the Zero or ZeroW. The power pins of the two micro-USB sockets are joined by PCB tracks. The limit will be set by the capability of the PSU or its cable or the PCB tracks burning up. No ordinary USB device should draw enough current to cause the last of those.
Posted: Fri Sep 13, 2019 8:44 am
by spaceman5
How nice..
On one hand it means no power limit,
on the other hand it means no protection, if the device for some reason has a problem like a short-circuit, and a resettable fuse would've helped..
Posted: Fri Sep 13, 2019 8:50 am
by fruitoftheloom
How nice..
All down to costs and what will fit on this type of PCB design.
Posted: Fri Sep 13, 2019 9:17 am
by spaceman5
I see.
BTW, there are 4 holes that we can solder pin headers to, above the inductor..
What are they for?
Posted: Fri Sep 13, 2019 9:32 am
by fruitoftheloom
I see.
What are they for?
You should read the MagPi Magazine it covers a lot more than can be gleaned from making multi post in these forums:
https://www.raspberrypi.org/magpi/rca-pi-zero/
Posted: Fri Sep 13, 2019 9:40 am
by alphanumeric
If the Pi was shut down and left powered up, momentarily grounding the Run pin will boot it up. You don't want to do that while its running though as it will like pushing the reset button on a PC. It will reboot on the spot without shutting down properly first.
RUN is actually the SOC Reset pin. It DOES NOT perform a safe shutdown, but can be used to restart the Pi after shutdown.
The TV pin I believe is the composite video out that would normally go out the analog audio jack, which the Zero doesn't have.
Posted: Fri Sep 13, 2019 10:05 am
by spaceman5
A Power On + Reset button,
sounds dangerous :)
OK I won't use it..
Oh,
all displays that you buy today have HDMI..
So this second pair can also be left unsoldered..
Posted: Fri Sep 13, 2019 10:21 am
by rin67630
The inductor is used to generate 3,3V for the processor AND, on the W the WiFi circuitry, which needs ~ 40% more current than the processor alone.
This is 5V sourcing, which is not provided from the circuit involving L1.
Posted: Fri Sep 13, 2019 10:23 am
by alphanumeric
I only ever solder a header there if I'm going to use the RUN pin. For most people, yes, just leave it as is. Only populate it if your actually going to use it.
Posted: Fri Sep 13, 2019 10:24 am
by rin67630
No. Many displays sold for the Pi have a SPI interface.
Posted: Fri Sep 13, 2019 10:25 am
by spaceman5
Thank you both.
How much mA each consumes, from your measurements?
Good point..
Posted: Fri Sep 13, 2019 11:22 am
by rin67630
AFAIR, headless, the Zero draws a 5,2 V 80mA idle, the ZeroW 120mA with an active WiFi connection in 5 meter range.
The figures are worse, if you connect a USB hub...
Posted: Fri Sep 13, 2019 11:27 am
by spaceman5
Wow 80mA that's so little..
My Zero and Zero W boards should arrive in 2 days,
would be interesting to do some measurements
Posted: Fri Sep 13, 2019 11:46 am
by fruitoftheloom
https://www.raspberrypi.org/documentati ... /#pi-power
Everything discussed has nigh on 4 years worth of relevant blogs, tutorials, how-tos et-al.....
https://www.raspberrypi.org/blog/raspberry-pi-zero/
https://www.raspberrypi.org/blog/raspbe ... ns-family/
Posted: Fri Sep 13, 2019 1:19 pm
by spaceman5
That FAQ page was terrific,
so much useful information, thank you very much..
Posted: Fri Sep 13, 2019 4:08 pm
by W. H. Heydt
Now you know why one of the oldest replies to computer questions is: RTFM.
Posted: Fri Sep 13, 2019 4:35 pm
by rin67630
I've done the measurements.
But remember: 80mA is just the bare Zero running at 700MHz with ~20% CPU using a 8GB SD card.
I use them with a GPIO serial link. The USB serial link will draw 30mA more!
Even a USB mouse/keyboard will increase the power requirements significantly.
As soon as you add video and USB hubs/peripherals, you will need more!
Posted: Fri Sep 13, 2019 5:12 pm
by FTrevorGowen
Have you tried powering via the USB-to-Serial device? It is possible (for the zero and some USB-to-Serial devices) :
http://www.cpmspectrepi.uk/raspberry_pi ... Powered.22
http://www.cpmspectrepi.uk/raspberry_pi ... es_Only.29
Trev.
Posted: Fri Sep 13, 2019 5:25 pm
by spaceman5
Really nice..
Since the board is powered with 5v and not 3.3v,
then this does not depend on the Serial Adapter's Voltage Converting capabilities (if any exists even)..
Some have an LDO to convert from 5v to 3.3v, and some use FTDI's "3.3VOUT" leg (leg #17) which gives only 50mA,
but here's it's not relevant and not a problem at all, it only depends on the USB Host socket that the Serial Adapter is connected to.
Posted: Sat Sep 14, 2019 6:36 am
by pollard5
Maybe because of the Power difference between Zero and Zero W they are using a strong inductor.
Posted: Sat Sep 14, 2019 8:00 am
by rin67630
Why considering USB and adapters?
The host (when connected) is a Pi3B and I connect using the GPIO.
