pi-tastic
latest rpi-update 2.5ghz with 4B 4g
Thu Sep 12, 2019 4:33 pm
Screenshot from 2019-09-12 12-30-31.png (13.12 KiB) Viewed 6420 times
Screenshot from 2019-09-12 12-30-17.png (12.42 KiB) Viewed 6420 times
Screenshot from 2019-09-12 12-30-04.png (31.08 KiB) Viewed 6420 times
its for sure making more heat however i have that under control lol
heatsinks and a blower!
maccaps.com - bringing life to dead electronics.
graphicw
Re: latest rpi-update 2.5ghz with 4B 4g
Thu Sep 12, 2019 9:51 pm
Please do me a favor and test it with CPU Burn and let us know how it performs. If you stay under 80 C then it will very interesting to see what you set up for cooling.
Moonmarch
Fri Sep 13, 2019 9:09 am
I have already seen several videos about overclocking the RPI4, 1 GHz overclock on the RPI4 that has to be a new record for any RPI computer, the RPI3b+ would be able to overclock to 1.6 GHz any higher clock speeds would prevent the computer from booting, the real test is using the computer with the overclock parameters to see if the computer freezes or programs crash frequently which would prevent the computer from being usable when I overclocked the RPI3b+ to certain CPU speeds Chromium would crash all the time, overclocking the GPU to certain speeds will cause graphic artifacts.
sparkyhall
Fri Sep 13, 2019 11:58 am
I suspect you are overloading the PMIC overclocking this high. The PMIC is a MxL7704 and the main out is rated to 4A, at 1V that's only 4W. When I ran my Pi4 at 2GHz the 5V supply current went from 1A at 100% CPU load to 1.5A, an increase of 2.5W. At a guess at 2.5GHz you are likely to have increased the input power by nearly 5W. I would be careful running stress tests for too long at this frequency.
akeda
Fri Sep 13, 2019 1:28 pm
Having read this thread, and believing clocking past 2GHz wasn't currently possible, I tested this yesterday.
Using the config.txt settings above,
vcgencmd measure_clock arm
shows a clockspeed of roughly 700MHz while running a stress script, while the /sys/devices...etc. method shows 2500MHz. The script takes forever, so the vcgencmd number seems to be more reliable. Same script at 2GHz is a lot faster...
The temperature in the above example also seems on the low side.
To sum it up: I believe the ARM is most probably running at 700MHz when setting i to 2500.
pi-tastic
Fri Sep 13, 2019 5:41 pm
oh golly your right:
frequency(48)=705164032 @ 2500
frequency(48)=1722251904 @ 2000
frequency(48)=1750412160 @ 1750
lol it appears its fastest @ 1750 lol.
graphicw
Sat Sep 14, 2019 5:47 am
I kind of figured it did not actually do 2.5 GHz. RPI happily chugs along up to 2 GHz with proper cooling. I run mine at 1.8 GHz because I shoot for an overclock that does not throttle with CPU Burn and my current cooling solutions in use. Once I have to bump over voltage to 4 or 6, the CPU still reaches throttle temp after a few minutes of running CPU Burn. This is with fan and heatsink. I get up to 1.8 GHz CPU and GPU of 600 MHz with over voltage set to only 2. That allows me stay under 70 C even in CPU Burn running for hours. I find CPU Burn to be the best tool around. You will never run that hard of a workload in a real world situation unless you are going NEON hardcore.
FPSychotic
Sun Sep 15, 2019 1:54 pm
i'm running rpi4 4gb at 2Ghz at constant 73C without issues. aluminium case with doube fan and SSD
kenkrsme
Sun Sep 15, 2019 2:04 pm
mine wont boot at 2.2 and is extremely unstable at 2.1. 2.0 is stable but wont cpuburn without freaking out. i run at 2.0, doesnt seem to effect my daily use.
pi-tastic
Mon Sep 16, 2019 5:29 pm
guys running 2.0ghz can you try
sudo vcgencmd measure_clock arm
From what i am seeing running @ 1750 seems to give me an actual higher speed.
Mon Sep 16, 2019 6:22 pm
Yes, 2GHz is the maximum settable, but at that power level, the PMIC is indeed right at the limits, so it may be unreliable after a while.
pi-tastic
Mon Sep 16, 2019 6:32 pm
yeah i cant set it higher then 1950 currently.
maybe i have caused the poor thing stress.
the good news is
1950486272 is what i am getting so that is good. @ 37c with HS and blower. lol
@ 4 for voltage
pi-tastic
Mon Sep 16, 2019 7:05 pm
this is the absolute best i can get out of er.
# force_turbo=1
over_voltage=6
gpu_freq=600
arm_freq=1979
frequency(48)=1979490176
i needed to put the voltage at 6 or else the speed would not maintain 1979490176
not even one notch more, lol, 1980 no dice. kicks out and starts to sit back a 1.7 ish.
however i am sitting at 50c lol... with heat sink and blower :)
facebook pops up alot faster now scroll seems smoother.
kenkrsme
Tue Sep 17, 2019 6:35 pm
arm_freq=2000
gpu_freq=600
over_voltage=5
frequency(48)=2000478464
pi-tastic
Tue Sep 17, 2019 8:47 pm
toms hardware was saying something about the silicon lottery lol
I have a 4B 4g at home have to check that one out.
The only issue is once i get home am consumed by family -- but its ok they are wonderful!
scaramonga
Wed Sep 18, 2019 2:20 am
I'd be 'under-clocking' it then :lol:
Wed Sep 18, 2019 7:43 am
I'd be installing PiHole and blocking all of their domains with it.
pi-tastic
Wed Sep 18, 2019 12:50 pm
this one at home seems to do better!
arm_freq=2000
gpu_freq=600
over_voltage=5
pi-tastic
Wed Sep 18, 2019 12:52 pm
oh man the temp chart is littered with red this thing is throttling like mad, --- neeeeeeed active cooling!!!
i have heatsinks on it too!
pica200
Wed Sep 18, 2019 3:13 pm
600 MHz + 2 GHz and overvoltage 6 makes it run a good 10°C higher than stock even with heatsink enclosure. Without extra cooling it will be on fire (not really)! I wanted to fine tune the voltage for a while but i'm missing a GPU stresstest. Something like cpuburna53 but for the GPU would be nice.
pi-tastic
Wed Sep 18, 2019 3:20 pm
we should do an energy consumption test @ those numbers how much extra is it eating?
i have the official psu and i notice at 1.9/2ghz it gets hotter!.
pi-tastic
Wed Sep 18, 2019 4:30 pm
What is funny is when i use a lower number for the voltage it takes longer to clock up to full speed.
sparkyhall
Wed Sep 18, 2019 7:16 pm
On my Pi4 the 5V supply current at default clock is 1A at 100% CPU load, at 2GHz it is 1.5A, an increase of 2.5W.
