johhnylatey
Xscreensaver alternative
Thu Sep 12, 2019 2:02 pm
Have a Pi4. Xscreensaver is the only screensaver I can find for Raspbian. Is there any others? Problems I've had with it: Won't open, window flashes then closes. Fix is to go Menu / Preferences / <Right click Properties>Screensaver. Click Desktop Entry tab and check Execute in Terminal, then OK button.
Then when you open it you will see the first error message which can be solved by Googling the CLI error and then downloading some extra packages. When done, you can go back to Properties and uncheck "Execute in Terminal Window".
Xsceensaver though will do as you set in the Screensaver Preferences, except after a certain time the screensaver will stop and the login box in blazing white appears.
I realise that "By default, the Raspberry Pi Desktop does not have any easy-to-use screensaver software installed" ... but why not? Could the devs answer why such a simple app isn't included?
pcmanbob
Re: Xscreensaver alternative
Sat Sep 14, 2019 11:19 am
I don't see why you are having problems installing Xscreensaver, on my pi4 I just did the following commands
sudo apt-get update
sudo apt-get install xscreensaver
then once the install was finished I did a reboot and the Xscreensaver was to be found in the menu under the Preferences option and just works .
So how did you do your install of Xscreensaver ?
graysky
Sat Sep 14, 2019 11:43 am
Xscreensaver is the standard. Open a terminal and type: xscreensaver-demo
What happens? If you see a crash, add the --debug option and post the output.
