edgararroyo
Raspberry Pi OS to host dockers only.
Wed Sep 11, 2019 9:52 pm
What is the smallest OS I can install on RPI to host dockers?
epoch1970
Re: Raspberry Pi OS to host dockers only.
Wed Sep 11, 2019 11:04 pm
boot2docker (Tiny Core Linux) is the smallest I know.
BeauSlim
Wed Sep 11, 2019 11:40 pm
I haven't used it extensively but there is HypriotOS ( https://blog.hypriot.com/ ) which is based on raspbian and designed to run docker.
Ubuntu's Core 18 might also be worth checking out: https://ubuntu.com/download/iot/raspberry-pi-2-3-core
Gavinmc42
Thu Sep 12, 2019 2:38 am
How many dockers?
Gentoo64 on a 4B4 can run 14+ Alpine machines.
I'm dancing on Rainbows.
edgararroyo
Thu Sep 12, 2019 3:07 pm
For now I am only going to run 3 dockers to host 3 MCPE phantom proxies (allows XBOX users connect to hosted MCPE servers)
So I guess the one that provides the most performance.
Thanks!
edgararroyo
Thu Sep 12, 2019 6:37 pm
@epoch1970 where can I get the boot2docker image for Raspberry Pi 3 B+?
epoch1970
Thu Sep 12, 2019 8:12 pm
That wasn't good advice, sorry.
I did not realise there was no build of boot2docker for ARM, only for Intel. That won't ever change since Docker has officially shelved boot2docker some time ago. Balena apparently has had an ARM port project, but that looks very much dead as well.
I suppose Hypriot is a more practical option.
edgararroyo
Fri Sep 13, 2019 12:05 am
Yeah, Balena also got rid of the macvlan driver/plugin so I can't use Balena. Will try Hipriot. Thanks.
