Imperf3kt
Contact: Twitter
Re: Fixing the Pi 4 usb C issue by hand
Thu Nov 14, 2019 1:24 pm
procount wrote:
Thu Nov 14, 2019 11:01 am
Or maybe just add 2 back to back adaptors:
Usb-c/micro-usb -> micro-usb/usb-c.?
I can confirm that USB-C cables do not appear to work when used like that.
(I've tried)
55:55:44:44:4C
52:4C:52:42:41
procount
Thu Nov 14, 2019 2:49 pm
Thanks for confirming it doesn't work. It was a suggestion someone made to me.
I guess it depends on whether the USB-C/micro adaptor contains the necessary cc resistors for power delivery. Often they don't say.
emma1997
Thu Nov 14, 2019 3:31 pm
hippy wrote:
Thu Nov 14, 2019 11:00 am
I doubt any company would create an adaptor for commercial sale as it would probably be too costly given the small market for such a board
What do you mean 'small market'? There have to be at least 3 individuals here in the US alone desperate for such a solution. Considering design and tooling should be able to produce such an item for as little as $200-$300 per. lol
I think there was a Shakespeare play on the subject: Much Ado About Nothing?
Imperf3kt
Contact: Twitter
Fri Nov 15, 2019 12:41 am
Stopping and thinking about it for a moment, a smart charger is supposed to default to just supplying 5v if it's plugged into a non smart device. At least, it does with micro USB.
What would happen if someone was to take a USB-C cable and only connect the vcc and GND wires into the Pi with something like this?
https://core-electronics.com.au/micro-u ... -pi-4.html
55:55:44:44:4C
52:4C:52:42:41
supersjimmie
Fri Nov 15, 2019 7:32 am
What I meant with the usb-c male/female could also be done with something like this:
https://www.aliexpress.com/item/33005988619.html
Then do exactly the same with adding one 5.1k resistor on te same pin.
That should work?
Or easier to compose, but less pretty:
https://www.aliexpress.com/item/4000026719770.html
clicky
Fri Nov 15, 2019 8:19 am
Brilliant! :D
HawaiianPi
Fri Nov 15, 2019 8:35 am
supersjimmie wrote:
Thu Nov 14, 2019 9:30 am
Instead of having to modify the rPI4 board, would it be possible to add the 5.1k resistor inbetween a male/female usb-c connector?
That way we can have just a small converter-cable with the resistor instead of the risk of ruining the rpi4 board.
Power adapter USB-C -> diy USB-C [male] -> diy cable with resistor -> USB-C [female] -> RPi4
Sure, that would probably work, assuming you made the correct connections, but I've got as even easier and less risky solution...
Just buy the official power supply. :roll:
davidcoton
Fri Nov 15, 2019 9:57 am
Somewhere here there is a thread that discussed how to modify a cable. Remember it has to work with both orientations of the plug. IIRC a one-resistor modification in the Pi end plug would work. Of course, the cable/adaptor is now useless for anything else. If you really need to use a smart charger, the mod to the Pi itself is as easy (not that easy, but within the scope of a competent amateur solderer) and saves having to buy extra kit (extra power connectors are in themselves a Bad Thing ™). If you don't want to modify your Pi, Just buy the official power supply.
supersjimmie
Fri Nov 15, 2019 10:00 am
Sure, but that won't answer the title of this discussion.
Fri Nov 15, 2019 10:12 am
No, but it will be cheaper.
Working in the Application's Team.
HawaiianPi
Fri Nov 15, 2019 10:22 am
Already been answered. Was there some other answer you were looking for?
procount
Thu Dec 26, 2019 5:43 pm
(I've tried)
@imperf3kt - Despite your experience, I decided to buy a pair of USB-C socket to micro-USB plug adaptors and tried one with my microUSB socket to usb-C adaptor. I chose these Arktek one's from Amazon (https://www.amazon.co.uk/ARKTEK-female- ... B071W8WQBD)
One of the adaptors was faulty, and wouldn't even work as a MicroUSB charger.
However, the other one worked fine back-to-back and allowed a USB-C PD charger to power my PI4.
So, it seems it would depend on the characteristics of the adaptor you use and specifically whether it includes the 2 CC resistors to tell the PD charger to deliver power.
Imperf3kt
Contact: Twitter
Thu Dec 26, 2019 10:02 pm
Nice to know.
I would mention the adaptor I have appears to includes some electronics.
This is the exact one I purchased.
https://www.bunnings.com.au/antsig-usb- ... k_p4360482
55:55:44:44:4C
52:4C:52:42:41
energyi
Mon Feb 24, 2020 2:16 am
W. H. Heydt wrote:
Tue Aug 27, 2019 7:18 pm
spooker wrote:
Tue Aug 27, 2019 7:23 am
Do we have any idea when rpi4 revision 2 that will fix this major flaw will be available?
The flaw is minor, so there's no hurry. I doubt the change will result is a Rev. 2 of the PCB. More likely to be 1.1 or 1.2, or even 1.0.1. I do not, personally, expect to see a revised board for about 6 months. Could be sooner, could be longer. It all depends on whether or not any other board corrections are found that need to be done and how urgent they are.
Just about exactly 6 months.
energyi
Stokestack
Fri Jun 05, 2020 11:32 pm
My Pi 4 just arrived from Adafruit today, and unfortunately it's the old version (2 GB model). So I decided screw it, I'm going to do this mod before I even fire it up. I will say that the only thing that made this task possible was an inspection microscope and some very, very pointy tweezers.
At that scale, you see how soft and flaky the metal is. As you're scraping away to break this tiny pin off the PCB pad, shavings are going everywhere. And you only get a couple of bends of the metal before it breaks. So it would have been very easy to ruin the whole connector.
In the end, it seemed to go fine. Unfortunately, I'm still waiting for my micro-HDMI adapters, so I haven't powered it up yet.
dickon
Fri Jun 05, 2020 11:39 pm
And you're planning to power it from..?
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
W. H. Heydt
Fri Jun 05, 2020 11:43 pm
Interesting... The one I got from Chicago Electronics last month is a v1.2.
Stokestack
Sat Jun 06, 2020 2:12 am
I have some Mac chargers, Motorola chargers, a windmill, waterwheel, clock tower...
jbudd
Sat Jun 06, 2020 1:42 pm
I have ... a windmill, waterwheel, clock tower...
It would be interesting to see details of [home made] wind and water turbines that can provide just enough power for a Pi 4.
Powering a Pi with a clock tower is especially intriguing! :D
Imperf3kt
Contact: Twitter
Tue Jun 09, 2020 12:45 am
Have you confirmed that you even need to perform this mod? By now, you should not be able to buy a Pi without the fix applied from new.
55:55:44:44:4C
52:4C:52:42:41
trejan
Tue Jun 09, 2020 1:54 am
The photo does show a v1.1. The v1.2 board has a small WLCSP component at the corner of the SoC near the WiFi shielding can. Presumably that is the SD card voltage switch that was mentioned as one of the v1.2 changes.
Stokestack
Tue Jun 09, 2020 3:17 am
Yes, as noted above, there's a component by the SD slot. And apparently no, you can't expect to receive a 1.2. Adafruit (rather huffily, it seemed to me) declares that there's no way for them to know which revision a unit is. As everyone in this thread knows, that's not technically true... but to be fair, they are in sealed boxes with no external markings. I think the unmarked boxes are a bit bogus on the manufacturer's part, but I understand not wanting resellers to be saddled with "obsolete" inventory that does work in most cases.
Meanwhile, I fired the thing up and it works great!
mmoseeker
Tue Jun 09, 2020 3:34 am
That should work?
too too long to deliver from aliexpress
ximon
Sat Aug 15, 2020 10:24 pm
This mod is only required to use e-marked usb-c to usb-c cables on a < v1.2 pi 4 isn't it?
I have a multiple usb-c to usb-a 2.0 cables that cause the pi 4 to just show a red light and not boot when plugged into a oneplus 6t charger, but it boots fine from a samsung charger.
