Dilligaf wrote:Actually the power output to the usb ports on a V2 board is only limited by the input fuse and the power supply so with a good enough power supply the drive will probably work. If you power the PI from the gpio bypassing the input fuse you could probably power multiple drives from the usb ports it was discussed in another thread and if I remember correctly the traces on the circuit board should handle about 2 amps
Now this sounds interesting. If we could somehow by-pass this fuse it would be great.
Has anyone done this, please post links.
I am guessing this would void warranty but that's ok too.
