Laui
Raspberry 4 issue
Sat Aug 24, 2019 6:21 pm
Since today I have the Raspberry 4 with 4 GB RAM. If it does not work with the power supply from the Raspberry 3? I have a USB-C adapter and a MicroHDMI to HDMI. I took out the SD card with Noobs from the 3, on it contain Raspbian & LibreELEC. Everything plugged, but nothing happens, no booting, screen keeps blank. The small red power light on the Raspi is on.
DirkS
Re: Raspberry 4 issue
Sat Aug 24, 2019 6:28 pm
You need to download the latest NOOBS version. Older versions do not work on the Pi4
Sat Aug 24, 2019 6:39 pm
You need at least NoobS installer / chooser V3.2, probably best to start afresh.
If you want a better NoobS then try PiNN:
https://www.raspberrypi.org/forums/view ... p?t=142574
Laui
Sat Aug 24, 2019 7:37 pm
Thank you
HawaiianPi
Sat Aug 24, 2019 7:42 pm
Thank you
You also need the latest Raspbian Buster. Your old Pi3 NOOBS card likely installed Jessie or Stretch, which also won't work on the Pi4.
