pams
Change wlan0 mac address via /boot/cmdline.txt
Fri Aug 23, 2019 5:04 pm
How to change wlan0 mac address via /boot/cmdline.txt?
Note that this question is not how to change wlan0 mac address via other means, such as: systemd, machanger, udev, etc. It is specifically via the above file.
To change the mac address of eth0 one would use, for example: smsc95xx.macaddr=DE:AD:BE:EF:CA:FE
How to accomplish the same for wlan0?
And where does one find all the configurable parameters?
Re: Change wlan0 mac address via /boot/cmdline.txt
Fri Aug 23, 2019 6:06 pm
The MAC address for WLAN is the ETH0 MAC address logically XOR'ed with 0x555555
So eth0 MAC b8:27:eb:3c:d8:c4
Gets wlan0 MAC b8:27:eb:69:8d:91
3cd8c4 == 0b0011 1100 1101 1000 1100 0100
XOR'ed w/ 0b0101 0101 0101 0101 0101 0101
698d91 == 0b0110 1001 1000 1101 1001 0001
I'm not sure if that still happens with smsc95xx.macaddr=mm:aa:cc:ad:dr:rs in /boot/cmdline.txt
This is a doctor free zone.
pams
Fri Aug 23, 2019 6:36 pm
Thanks Dougie!
I can confirm that after changing the MAC address of eth0 (via /boot/cmdline.txt), wlan0 will correspond not to the changed, but the original mac address of eth0 XOR'ed with 0x555555.
What I'm left wondering now is: how can you possibly know that? :)
Is it on some boot script?
Fri Aug 23, 2019 7:35 pm
It's on some historic forum posting just after the Raspberry 3B with on-board WiFi appeared.
Andyroo
Fri Aug 23, 2019 7:53 pm
:o clunk
That clunk is my jaw hitting the floor...
Fri Aug 23, 2019 7:59 pm
:o clunk
I'm available when you're sitting in front of Jeremy Clarkson and it's the WWTBAM £500,000 question ("How is the WLAN MAC address generated on a Raspberry Pi") and you need a "phone a friend". My brain is full of 40 years worth of technical junk (or at least a pointer to where find it).
https://www.raspberrypi.org/forums/view ... 1#p1278764
Andyroo
Fri Aug 23, 2019 8:09 pm
Mine used to be till I broke it :cry:
Maybe you need to write a ‘1001 things you never knew about the Pi’ book?
I’d buy it.
