wiser
Motor controller board
Fri Aug 23, 2019 3:59 am
My L298n motor controller board that goes with a raspberry pi isn't lighting up even though it is connected to a power source (4 AA batteries). Does anyone have any solutions to this?
jondallimore
Re: Motor controller board
Fri Aug 23, 2019 12:26 pm
check power leads, check solder joints, check batteries with a multimeter
theres so many things it could be...
pcmanbob
Fri Aug 23, 2019 6:43 pm
Hi.
You really need 7 volts on the battery input before the on board voltage regulator will function, these L298N boards are really designed to operate with a 12v battery.
wiser
Fri Aug 23, 2019 11:51 pm
I did check my solder joints and power leads. Will 4 AA batteries be enough for this board?
pcmanbob
Sat Aug 24, 2019 10:12 am
4 X 1.5V = 6v No load, so under load when the motors are running the voltage will probably be nearer 4-5v so the on board voltage regulator will just about work at 6v but will stop functioning at 4v.
As I said these L298N boards are design to operate with a 12v motor supply, at lower voltages the volt drop across the controller chip will consume much of your battery voltage , which will lead to your motors being slow or not functioning.
wiser
Sat Aug 24, 2019 6:09 pm
Will a raspberry pi and 4 AA batteries together be enough to light the motor controller board up?
pcmanbob
Sat Aug 24, 2019 6:24 pm
What's up don't you like my answer above ?
Asking the question again won't change the answer.
jondallimore
Sat Aug 24, 2019 10:38 pm
wiser wrote: ↑
You've already tried with 4 AA batteries. I would use at least 8 AA's, but preferably a li-po battery from an rc car (12v again).
Or the board could be fried.
wiser
Sun Aug 25, 2019 2:26 am
Ok
