LapDock with rev 2 (512MB) Pi
Posted: Fri Dec 07, 2012 6:48 pm
I haven't played with either of my original rev 1 boards for quite some time; however, I did connect my new rev 2 China made (512MB) board to my Motorola LapDock today. Follows are my observations.
I am powering the Pi via the MicroUSB connection on the LapDock using an unmodified microUSB/USB cable to one of the two USB ports on the Pi. This means I am back powering the Pi and NOT using the microUSB power port on the Pi. Powering this way is safe on the rev 2 boards, correct? On the rev 1 boards I only connected the data lines to the Pi USB hub and powered the Pi with a wall-wart (IE.. never made the y-cable). I also plugged my USB wireless adapter into one of the USB ports on the LapDock and it worked!!! On my two rev 1 boards, I had to disable the wired Ethernet with a command before plugging in the WiFi adapter or the Pi would lock up. If it safe to power the rev 2 Pi through the USB hub, this would eliminate the requirement to make a (data only) y-cable.
Final question, does the current Raspbian download take advantage of the 512MB of onboard RAM yet?
