Rachelle
Looking for Pi management platform
Wed Aug 21, 2019 9:30 am
Hi all,
I've been looking for some kind of raspberry pi management portal for about 2 full days now, but I never really get what I need.
We're currently working on some fun gadgets for our presentation room at our office and we're looking at expanding in the future. At the moment we have 3 raspberries (1 RBP zero and 2 RBP 3B+). They are all on the same network and their IP addresses should be static.
At least 2 are running on a their own 4000mah powerbank, but the third one should also use one in the future. I hope to replace them with better/smaller ones that last longer or 3d print a charging station.
I was thinking about adding a cronjob to automatically shutdown the pi's at 5 PM, but the batteries probably won't even last that long.
Like I said, I tried a few iot management portals, but they all seem to be geared more towards data collection. All I need is a simple application that allows adding new devices (fill in IP and ssh password), ping them to see if they're reachable, a reboot and a shutdown function. The "sleep mode" after shutdown is fine for now I think. I read that the pi typically uses 20-30 mA.
neilgl
Re: Looking for Pi management platform
Wed Aug 21, 2019 11:12 am
On my galaxy S9 phone I use “RasPi Check” for checking various pi and shutting them down etc. Simple to add a pi using IP address
Eitan-UpSwift
Tue Aug 27, 2019 9:25 am
Hi Rachelle! You can try our management platform for IoT devices - https://www.upswift.io. It takes only 60 seconds to register any Linux device, it's free and fully featured for your first 3 devices. :D
(Of course, all of the RaspberryPi models are perfectly supported)
The platform has all the features that you mentioned, and even more (remote control, deploying OTA software updates, etc..)
Disclaimer - I am working at UpSwift.io
UpSwift.io - Manage and Control remotely RaspberryPi and IoT devices.
Andyroo
Tue Aug 27, 2019 10:17 am
How about creating your own?
Use MQTT to send instructions to each Pi
Use MQTT to receive a heartbeat from each Pi
Create a topic for each Pi and a simple script or Python program to handle it running in the background.
If you want to get posh you could use node-red to take action / monitor them.
You could also look at https://www.balena.io/cloud where the first 10 devices are free, https://remote-iot.com/pricing.htm ($0.1 per dev commercial per month) or even Nagios for true LAN monitoring https://baldnerd.com/nems/
