luc1970
File transfer speed with the Pi4
Mon Aug 19, 2019 6:56 pm
I wonder what file transfer speed one could expect with the new Pi4 and its USB3 ports. If two HDDs or USB sticks are plugged into the USB3 ports, has anyone measured the file transfer speed from one to the other ?
Re: File transfer speed with the Pi4
Mon Aug 19, 2019 7:11 pm
A maximum of 2Gb/s in theory, although it will likely be less than that.
clicky
Mon Aug 19, 2019 7:14 pm
$ sudo hdparm -t /dev/sda
/dev/sda:
 Timing buffered disk reads: 852 MB in  3.00 seconds = 323.61 MB/sec
Does this tell you anything?
BTW 323.61 Mbytes per second is 2588.88Mbit per second...
ejolson
Mon Aug 19, 2019 7:16 pm
/dev/sda:
Right, so if copying from one device to the other, one would expect a total throughput of about half or 1294.44 Mbit per second.
Mon Aug 19, 2019 7:22 pm
Not quite. It depends on the speed of the slowest device involved as well.
Writing is slower than reading.
Short burst writes will use the device's internal cache, so will run at the best speed the device/host bus can handle.
Sustained writes will run as fast as the device being written to can handle unless the bus speed is slower.
luc1970
Mon Aug 19, 2019 9:08 pm
Well thats all theory, in my first try I had something like 20MBytes/sec, which is not much. With the same disks on my mac I have around 150MBytes/sec, so I was wondering what people were experiencing in reality...
All huge files btw, not thousands of small ones.
RaTTuS
Mon Aug 19, 2019 9:18 pm
what devices ,
how are you measuring ?
post URL's to all
Covfefe
luc1970
Mon Aug 19, 2019 9:39 pm
Well I copied 16GB of movies in 14min from one to the other, which gives around 20MByte/sec. HDDs are Seagate Freeagent Goflex https://www.storagereview.com/seagate_g ... tac4000100. On my mac, they are about 7x faster.
ejolson
Tue Aug 20, 2019 12:02 am
In that case you will want to read the following thread:
https://www.raspberrypi.org/forums/view ... 8&t=245931
clicky
Tue Aug 20, 2019 6:47 am
$  ls -la big_file
-rw-r--r-- 1 pi pi 10878393190 Aug 20 07:41 big_file
$ time cp big_file big_file2
real	1m38.212s
user	0m0.114s
sys	1m8.833s
10878393190 bytes / 98s = 111004012 which is 105MB/s
So, yes, 150MB or less is realistic.
