geffers
Change root in cmdline.txt
Fri Aug 16, 2019 4:35 pm
Folks,
Think I misunderstood something some time back that I read in an article somewhere.
In the cmdline.txt file in the /boot directory there is an entry as follows;
root=PARTUUID=c82337fe-02
which seems to allow setting the root directory to a different location.
Now I am thinking you need the operating system to load before it can recognise the attached storage device so what is the point of altering this location?
Geffers
ejolson
Re: Change root in cmdline.txt
Fri Aug 16, 2019 4:48 pm
Folks,
Geffers
You are right. The bootloader first loads the Linux kernel from the FAT partition. Once loaded the kernel consults the root= setting to know which device contains all the user and system files that are part of the operating system and everything else. Setting root to a device other than the SD card allows running, for example, from an external USB drive after the initial program load of the kernel is finished.
geffers
Sat Aug 17, 2019 10:12 am
Now obviously I've done something wrong then.
I copied the actual ext4 partition (not just files within, used gparted to copy partition) to an external drive, got the PARTUUID then checked ID same when plugged in the the Pi.
Then deleted the ext4 partition on the SD card having altered the location of root to the PARTUUID on the cmdline.txt
Didn't boot, tried twice but then thought perhaps I misunderstood the setup.
Worked in the past but then didn't delete the ext4 partition on the SD card, all appeared to work but then I was unsure where OS was actually working from even though I had changed the root location.
Geoff
thagrol
Sat Aug 17, 2019 10:37 am
You need to edit /etc/fstab to match the new location as well.
Arguing with strangers on the internet since 1993.
Roken
Sat Aug 17, 2019 10:54 am
For clarity, that's /etc/fstab on the NEW root partition. But you can simply comment out the / mount in the new fstab.
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
graysky
Sat Aug 17, 2019 11:05 am
I think there is a kernel parameter you need to change as well.
thagrol
Sat Aug 17, 2019 11:19 am
Not in my experience. /boot/cmdline.txt and /etc/fstab on the new partition is all I've ever had to change.
graysky
Sat Aug 17, 2019 11:38 am
No, it's hardcoded:
On Arch ARM: https://github.com/archlinuxarm/PKGBUIL ... onfig#L517
On Raspbian: https://github.com/raspberrypi/linux/bl ... config#L47
Could be possible to override elsewhere, IDK.
HawaiianPi
Sat Aug 17, 2019 11:49 am
Which model PI?
What OS?
What are you using for a power supply?
What kind of drive are you attempting to load the OS from?
For systems not capable of true USB boot, the simplest solution is to clone the entire card to the USB drive (preferably with the SD Card Copier utility included with Desktop versions of Raspbian), then copy just the bootcode.bin file to a FAT32 formatted SD card. That will load and run the entire OS from the USB drive on all models up to the 3B+ (although the 3B+ can USB boot without a card as well).
The new Pi 4B does not currently support USB booting, and does not use the bootcode.bin file, so you do need to have /boot on the card (for now). In that case, clone the card to the USB drive, then copy the contents of the "boot" partition to a FAT32 formatted micro SD card. After the system boots, edit /etc/fstab to mount the SD card as /boot (followed by a reboot) so that firmware and kernel updates are properly applied.
Forum member RonR has some handy scripts that can simplify the process.
thagrol
Sat Aug 17, 2019 12:12 pm
No, it's hardcoded:
For raspbian that's the default config (hint: it's in the filename). That's clearly overridden by /boot/cmdline.txt otherwise all those things that rely on changes to cmdline.txt (quirks for UAS devices, moving root partition, serial console, etc) wouldn't be possible.
Don't know about Arch as I don't use it but I'd expect iot to be the same.
tpylkko
Sat Aug 17, 2019 7:10 pm
If you boot with your current settings, what error do you get?
Milliways
Sat Aug 17, 2019 11:43 pm
With the new default settings there is a Splash screen and there are NO error messages for a missing root partition.
To clarify - if you select Splash screen on boot (default) this will be shown, with minimal messaging.
If the root partition is inaccessible the display will show 4 raspberries - but no error messages (and obviously no Splash screen).
If you restore text boot you will see boot messages, including errors e.g. indicating missing root fs.
thagrol
Sun Aug 18, 2019 12:21 am
If you restore text boot you will see them.
Which splash screen? The rainbow square from the early bootloader or the one shown when the GUI is starting? (loaded from /usr/share/plymouth/themes/pix/splash.png so your root partition must be mounted and accessable).
If the latter, try appending
quiet splash
to /boot/config.txt and rebooting/power cycling.
If the former, something is very wrong with your system as it would appear that the initial boot loader can't find a FAT partition to boot from.
Edit:
A couple of other approaches:
  • If you have access to another Pi and haven't removed the neccessary stuff from cmdline.txt you can make a serial connection between them and monitor the boot messages via that.
  • Likewise if you access to a USB to 3.3v serial dongle and another computer.
  • If the hang is on the desktop/gui splas screen, trry scanning your network for that Pi. If it shows up try to ping it and to connect via ssh.
geffers
Tue Aug 20, 2019 10:08 pm
Thanks, that worked spot on. Soon as I altered fstab it worked fine.
Geffers
geffers
Tue Aug 27, 2019 11:36 am
Which model PI?
What OS?
It was only an experiment but for your info;
  • Pi Model 2B (Not 2B+)
    Buster-lite
    Raspberrypi 2.5 Amp PSU
    Copied the new Ext4 partition of a working installation from MicroSD card to an external USB 2.5" hard drive, left the FAT32 partition on MicroSD card for booting purposes.
    I deleted the Ext4 partition from the MicroSD card
As original post said I changed the entry of root in the cmdline.txt file to show new external drive. I forgot to alter the /etc/fstab file - once I did that all worked fine.
Appreciate it is booting from the MicroSD card but from then on external 2.5" drive is the source.
Geffers
