So I can't be the only one wanting this.
The rest of us have more patience though !thatchunkylad198966 wrote: ↑Fri Aug 16, 2019 10:07 amWhen can we expect USB boot for the Pi 4?
So I can't be the only one wanting this.![]()
Yeah well when I tried that, my Pi 4 4GB wouldn't boot and I spent hours on IRC with the help of #raspberrypi and I kept on getting a kernel panic. no matter what I tried. /boot was on the SDCARD and /rootfs was on my USB3 SSD via USB3 to SATA.HawaiianPi wrote: ↑Fri Aug 16, 2019 11:02 amIt's simple enough to have /boot on SD card and / (the rootfs) on a USB drive, and that works fine for now (if you really can't wait).
That's how my 4B2 is configured at the moment. I swapped it for my Pi 3B in this case, and it's been working great since I received it.
The issues are likely to do with the particular USB3 to SATA interface you have (apparently some chipsets do not play well with the the Pi, not sure if it is just isolated to the USB3 interface though). There have been reports that updating the firmware on the USB/SATA interface module has resolved the issue for some people.thatchunkylad198966 wrote: ↑Fri Aug 16, 2019 11:07 amYeah well when I tried that, my Pi 4 4GB wouldn't boot and I spent hours on IRC with the help of #raspberrypi and I kept on getting a kernel panic. no matter what I tried. /boot was on the SDCARD and /rootfs was on my USB3 SSD via USB3 to SATA.HawaiianPi wrote: ↑Fri Aug 16, 2019 11:02 amIt's simple enough to have /boot on SD card and / (the rootfs) on a USB drive, and that works fine for now (if you really can't wait).
I read on here (can't find it right now) that if I would've plugged the USB3 HDD into the USB2 slot, it would've booted.
Think I'll pass and wait.
+1bjtheone wrote: ↑Fri Aug 16, 2019 1:07 pmThe actual process to setup boot from SD and run from USB connected storage is literally one rsync command and editing 2 files. If you have an issue with the USB to SATA interface you are using, getting boot from USB support in the firmware on the PI is not going to magically resolve this. I agree from a purist point of view, the current solution is not boot from USB, and I do still need the SD card installed, but nothing is getting written to the SD and it provides the same performance improvement so I think that prioritizing "real" issues makes sense.
IIRC it is because network boot is easier/quicker to implement. USB boot needs a lot more new code to be added and testing is more complicated.
Pi-net is quite popular in education, which is the primary target usage for the Pi. It may not be where most of the sales go, but it is the whole idea behind the Pi and what it stands for.
It's more likely catering to educational needs, which is--after all--the primary goal of the RPF.
Only if one is satisfied with a hybrid boot (and that has already be mentioned in this thread). If one actually wants "USB boot", then waiting is in order.RonR wrote: ↑Fri Aug 16, 2019 4:56 pm
Right now: Running Raspbian on USB Devices : Made Easy
No complicated steps involved or additional tools required.
Between you and all the RPT/RPF people, which do you think knows their business best ? Hint: It's not you
W. H. Heydt wrote: ↑Fri Aug 16, 2019 5:18 pmOnly if one is satisfied with a hybrid boot (and that has already be mentioned in this thread). If one actually wants "USB boot", then waiting is in order.RonR wrote: ↑Fri Aug 16, 2019 4:56 pm
Sarcasm: Hostility disguised as humor. Gotta love it!
If people didn't care about the distinction, this thread would not exist.
No sarcasm at all ! It's amazing how often people come here and claim that their particular requirements are the most important and that RPT should be building what ever it is that they need. Just look at all the "Pi4 must have a XYZ" threads and see how many of them have been locked.
W. H. Heydt wrote: ↑Fri Aug 16, 2019 5:55 pmIf people didn't care about the distinction, this thread would not exist.
You're getting overly hung up on the connection layer with the HDD on this.W. H. Heydt wrote: ↑Fri Aug 16, 2019 5:18 pmOnly if one is satisfied with a hybrid boot (and that has already be mentioned in this thread). If one actually wants "USB boot", then waiting is in order.RonR wrote: ↑Fri Aug 16, 2019 4:56 pm
