GuppyHJD
Protect over voltage on Voltage Divider ciruit
Sat Aug 10, 2019 12:57 am
I am trying to monitor a remote 12v battery. When I do the math for a voltage divider R1 = 1000ohm, and R2= 330 ohm, gives me 3.49 v if the battery is at 14v. If it is at normal 13.1v to 12.8v the output voltage drops to 3.25v to 3.177v. I am wondering, is there a way to protect the Raspberry Pi pins from anything over 3.3v? I don't want to fry the Raspberry Pi.
PhatFil
Re: Protect over voltage on Voltage Divider ciruit
Sat Aug 10, 2019 1:40 am
You do have some leway below 3.3v the pi will register a high with voltages over +1.8-2v referenced to ground? (look that up or test it..)
http://www.mosaic-industries.com/embedd ... ifications
or you could employ an optically linked indicator, https://shop.pimoroni.com/products/spar ... AeEALw_wcB
or a logic level shifter
dl324
Sat Aug 10, 2019 1:46 am
You could use a voltage comparator like LM393. Just connect the pull-up resistor to 3.3V. You can operate the comparator from 5V or your battery voltage.
drgeoff
Sat Aug 10, 2019 8:41 am
Or put a 2.7 volt zener diode across R2.
Quis custodiet ipsos custodes?
davidcoton
Sat Aug 10, 2019 8:48 am
The resistor in the voltage divider should be enough protection, up to 4V on the GPIO pin (so over 16V at the battery). Note this is outside the recommended operating conditions but should give adequate protection for an unusual condition. Beyond that you could clamp the GPIO pin via a diode to 3V3, or use a 3V3 zener diode to ground (also gives reverse polarity protection).
GuppyHJD
Sun Aug 11, 2019 1:57 am
Thank you for the replies. I have ordered a few Zener diode.
trejan
Sun Aug 11, 2019 2:05 am
Use bigger value resistors as you'll be dissipating ~10mA across your voltage divider with your current selection. You may need a 10-100nF ceramic cap from the ADC input to ground as well.
Burngate
Sun Aug 11, 2019 9:27 am
I'm not convinced about using higher value resistors.
With 1k & 330Ω across 14v, it's only dissipating ~150mW, well within what a standard ¼W through-hole resistor can handle, though a bit much for a standard 0603 Thick Film SMD Resistor ±1% 0.1W.
The OP states
To me that means there's a long distance between the battery and the Pi, with all the problems of interference along the way.
As the resistor values go up, so do the problems, so I would be considering reducing the values, not increasing them.
drgeoff
Sun Aug 11, 2019 9:57 am
What ADC? No mention in this thread of an ADC until trejan's post.
trejan
Sun Aug 11, 2019 10:19 am
If they want to know the exact voltage then they'd need one. If they're happy with knowing they're just over some preset voltage then no.
trejan
Sun Aug 11, 2019 10:23 am
I was more concerned about unnecessary drain on the battery than the resistors themselves. It isn't huge but it may make a difference if they're trying to maximise battery life. I think OP needs to post more details about what they're trying to do.
drgeoff
Sun Aug 11, 2019 10:24 am
The threshold voltage on a RPi GPIO is not sufficiently well defined to know with certainty if above or below some preset voltage.
trejan
Sun Aug 11, 2019 10:46 am
Add an ADC then :roll:
