jondallimore
Run fan off USB port
Thu Aug 08, 2019 2:55 pm
with a pi 4 - I want to keep the GPIO pins for something else.
Is there any reason I couldnt run a 5v fan from one of the USB ports?
I assume I could use a USB 2.0 port - ideally I dont want to 'waste' a USB 3.0 port.
Also is there any way to turn USB ports on and off?
thanks
Jon
trejan
Re: Run fan off USB port
Thu Aug 08, 2019 3:03 pm
You only have 1.2A in total across all 4 USB ports. If your fan and any other USB peripherals doesn't exceed that then you should be okay. Test it first.
Yes.
Yes but you turn on/off all 4 ports together. You can't control power to individual ports. Use https://github.com/mvp/uhubctl
jondallimore
Thu Aug 08, 2019 3:18 pm
hmmm... current isn't a problem as one of the USB 3.0 ports is getting a powered hub, but would want to turn them off individually which wont happen... maybe I'll have to use GPIO and bugger about with it a bit to make the other stuff fit.
The other option is the Power Over Ethernet pins, but I dont know enough about that... can they be made to output 5v? and if so, how?
trejan
Thu Aug 08, 2019 3:20 pm
You can try uhubctl on your USB hub as well. Some of them do let you control power to each individual port.
No. Those pins connect to the center taps of the Ethernet transformers inside the socket.
jondallimore
Thu Aug 08, 2019 3:27 pm
ahh you mean control the ports on the hub? thats interesting, will have a fiddle with that.
thanks
Imperf3kt
Thu Aug 08, 2019 10:32 pm
The black plastic strip won the base of the GPIO can be removed with a small flat screwdriver and working gently from end to end.
Removing it will give you an additional ~2mm of pin you can solder additional wires to without interfering with hats.
55:55:44:44:4C
52:4C:52:42:41
wh7qq
Fri Aug 09, 2019 9:00 pm
Good info...never thought of that.
drgeoff
Fri Aug 09, 2019 9:05 pm
Or solder to the GPIO pins on the underside of the board. The electrons cannot tell the difference.
Quis custodiet ipsos custodes?
MalPi
Sat Aug 10, 2019 12:12 pm
That is true, it is because they are leptons and have no quarks.
Only the hadrons (proton, neutron etc.) have up, down, top and bottom quarks.
:o :D :mrgreen:
I'll get my coat >>>>>>
Burngate
Sat Aug 10, 2019 5:16 pm
:o :D :mrgreen:
I find that strangely charming
Though neutrinos, also leptons, do know left from right.
W. H. Heydt
Sat Aug 10, 2019 5:22 pm
Annnddd back on topic...
Here https://www.frys.com/product/5442979?si ... IN_RSLT_PG is a fan designed to run from a USB port. It even has a speed adjustment.
jondallimore
Sat Aug 10, 2019 5:29 pm
ended up using a breakout board with a ribbon cable, and forcing it to accommodate some solid core wire alongside the 5v and ground pins - gives me 5v for the fan, and will build a board to switch it when 70 degrees is reached.
Prefer it to soldering as I can take it apart easier if needs be.
I think the leprechauns know the way...
