going back to topic....any projection when the supply leveling off with the demand?
Given the huge numbers we are making, and the production shift to favour 4GB, and the large demand....no, no idea! I've sure some people have an inkling, but I am not privy. Months rather than weeks would be my guess.
Oh oh...might as well really wait until the holidays then.... don't want to deal with some "black market" sources anyway....
You should be able to order at any time and get within a sane timescale - I was talking about the time when you can buy and definitely get next day delivery from most suppliers.LTolledo wrote: ↑Tue Aug 06, 2019 12:41 pmOh oh...might as well really wait until the holidays then.... don't want to deal with some "black market" sources anyway....
having none (any variant) is somewhat "keeping me out of the loop" at the moment.....![]()
When demand reduces. It won't remain at current "must have" level indefinitely.
In other words...typical--and probably unavoidable consequence--of a new Pi launch.
I don't think anyone has said that the Pi4B4 is "unnecessary", only that it's not needed for *every* use case. The debate really comes down to the degree to which one might expect people (in general) to know when 4GB is needed and when it is not. I have a use for several Pis for which I'm considering whether to go with Pi2Bv1.2 (which can certainly handle the job) or Pi4B1 (also adequate).
The problem--at least as I see it--is two-fold. First, it would require the RPF/RPT to maintain two versions at least at the kernel level. Not necessarily twice the work, but certainly more than only one kernel. Second, there are several models of Pi--some in common use--that simply can not run a 64-bit OS, even if it's just the kernel. One of those has a guarantee that it will be in production (and that implies software support) for at least another 3 or 4 years. Find the RPT as fully suitable and cost equivalent replacement for the BCM2835, *then* start talking about a move to 64-bit.And in my opinion there should at least be an official 64 bit kernel for the ARMv8 Pis so users have the option to run 64 bit software if they want (and take advantage of the improved instruction set for software which benefits from it). The 32 bit userland can still be default. No harm there![]()
That has to be balanced against the spread of knowledge that Pis even exist.
The Pi4 is the first Pi truly capable of desktop use. Word may be getting out.W. H. Heydt wrote: ↑Tue Aug 06, 2019 7:42 pmThat has to be balanced against the spread of knowledge that Pis even exist.
I wonder if we should have priced the 4GB version a bit higher! $65 maybe?Fraoch wrote: ↑Tue Aug 06, 2019 8:00 pmThe Pi4 is the first Pi truly capable of desktop use. Word may be getting out.W. H. Heydt wrote: ↑Tue Aug 06, 2019 7:42 pmThat has to be balanced against the spread of knowledge that Pis even exist.
People new to the Pi from the Windows world are trained to think more RAM is always better. So they order the 4 GB version.
They're unaware that Raspbian is highly optimized for low RAM usage. They can't conceive of a desktop using anything less than 4 GB of RAM, and even 4 GB may feel uncomfortable.
I can certainly appreciate all the hard work the devs did in getting Raspbian Buster as efficient as it is - it runs on my 1B, just barely.
I probably wouldn't have bought a Pi4 if you had. The current price was stretching my budget a lot. I could have gone for a smaller memory version, but didn't really want to.
LOL, well if people really feel they need 4 GB without doing their research to determine if they really need it, might as well make some profit!
There is more behind the decisions though. I bet many have the future in mind where software keeps growing and eating more RAM. Investing more now means investing less in the future. It will work longer with common software --> less electronics waste and such. The Pi 4 is probably my last one for a good while since i own 4 in total nowW. H. Heydt wrote: ↑Tue Aug 06, 2019 7:41 pmI don't think anyone has said that the Pi4B4 is "unnecessary", only that it's not needed for *every* use case. The debate really comes down to the degree to which one might expect people (in general) to know when 4GB is needed and when it is not. I have a use for several Pis for which I'm considering whether to go with Pi2Bv1.2 (which can certainly handle the job) or Pi4B1 (also adequate).
There is not much to do after the initial fix marathon of drivers. After that it's just building the kernel twice. I think that's a worthwhile tradeoff for giving the user a choice. In fact there is an unofficial kernel floating around and it's working with a few limitations.W. H. Heydt wrote: ↑Tue Aug 06, 2019 7:41 pmThe problem--at least as I see it--is two-fold. First, it would require the RPF/RPT to maintain two versions at least at the kernel level. Not necessarily twice the work, but certainly more than only one kernel. Second, there are several models of Pi--some in common use--that simply can not run a 64-bit OS, even if it's just the kernel. One of those has a guarantee that it will be in production (and that implies software support) for at least another 3 or 4 years. Find the RPT as fully suitable and cost equivalent replacement for the BCM2835, *then* start talking about a move to 64-bit.
Wow, check out all the RAM shaming.
I'm up to 4 Pi4Bs...so far. The use I have in mind for the 1GB boards requires running the desktop and a single instance of PuTTY. This doesn't take a lot of RAM. The reason that the Pi2Bv1.2 is in the running is itself a "future proofing" act, as those boards could run a 64-bit OS, unlike the Pi2Bv1.1 boards that are in current use. The virtue of the Pi2B is no WiFi. (And yes, I do mean that.) So even though the price is the same, it will really be a considered decision with neither one having a overwhelming advantage.pica200 wrote: ↑Tue Aug 06, 2019 9:08 pmThere is more behind the decisions though. I bet many have the future in mind where software keeps growing and eating more RAM. Investing more now means investing less in the future. It will work longer with common software --> less electronics waste and such. The Pi 4 is probably my last one for a good while since i own 4 in total nowW. H. Heydt wrote: ↑Tue Aug 06, 2019 7:41 pmI don't think anyone has said that the Pi4B4 is "unnecessary", only that it's not needed for *every* use case. The debate really comes down to the degree to which one might expect people (in general) to know when 4GB is needed and when it is not. I have a use for several Pis for which I'm considering whether to go with Pi2Bv1.2 (which can certainly handle the job) or Pi4B1 (also adequate).![]()
This is a Raspberry forum, not a Potato one.
That it is a Raspberry forum does not deter many turnip-heads from posting here.
We all got hit by several years of stagnation in the RAM market. In fact, the stagnation has lasted from about 2012 to 2019, or the entire history of the Raspberry Pi. The $45 and $55 models bypass that issue by allowing buyers to throw more money at it. But if 2 GB, 4 GB, 8 GB, 32 GB, 1 TB, etc. of RAM were to cost the same as 1 GB does right now, the $35 base model would likely include that much.davidcoton wrote: ↑Tue Aug 06, 2019 10:14 pmBut part of the Raspberry Pi ethos has been to do as much as possible with minimal hardware (and thus the lowest possible price). Maybe the 4GB Pi4B will mark a move away from this, back to the "throw hardware at it" solution to IT problems.
12 GB LPDDR packages for smartphones are available, and 16 GB is coming soon. In a decade, there will be higher capacities, and possibly universal memory with density similar to NAND.Q: What features would you like to have on the Raspberry Pi 5? Also are there any features in your mind that make you say, "It would be great if we had it, but alas, we cannot"?
Eben Upton: The interesting thing is that really our feature set hasn't changed since Raspberry Pi 3B in 2016: newer models just have "more" of everything, even if all of that "more" sometimes stacks up to a more qualitative change (e.g. from "not a PC" to "a PC"). I suppose Raspberry Pi 5, whenever it arrives, is likely to just have more of everything. One hope is that over the next few years we see enough decline in RAM prices to allow us to fit more memory into the baseline $35 device.
Oh wait...I get it....it's like Descartes, "I Rasp therefore I am"W. H. Heydt wrote: ↑Tue Aug 06, 2019 7:42 pmThat has to be balanced against the spread of knowledge that Pis even exist.
Not quite.
Nice. How about:
It is not enough to have a good Pi; the main thing is to use it well.
Everyone that will ship in a timely fashion is limited to one per order (some say one per household). Sellers like Newark who will let you order quantities are so far back-ordered you probably won't receive them this year (not kidding or exaggerating).
