Rootinator
Sound card as default
Wed Jul 24, 2019 8:43 pm
PulseAudio is used as a driver on the Raspberry.
How can I set my external USB sound card as default here?
The following did not work:
sudo nano /etc/asound.conf
pcm.!default {
 type hw
 card 1
 device 0
sudo nano /etc/modprobe.d/alsa-base.conf
#change the index from -2 to 0:
options snd-usb-audio index=0
Both files do not exist. Even after creating these files it does not work.
bcm_2835 is disabled.
ElectronicMusicWebradio -- The best of electronic & dance music!
www.WT-Radio.de
andrum99
Re: Sound card as default
Wed Jul 24, 2019 9:51 pm
If the built-in sound (bcm2835) is disabled, then your sound card will become the default without you needing to do anything. How did you disable bcm2835?
Rootinator
Thu Jul 25, 2019 10:22 am
sudo nano /boot/config.txt
dtparam=audio=off
andrum99 wrote: If the built-in sound (bcm2835) is disabled, then your sound card will become the default without you needing to do anything.
That's the problem. The external sound card is only sporadically recognized and used.
With the command "aplay -l" it does not show a sound card at this time.
In addition, I always have, if I want to change the volume with
alsamixer
first select the external sound card.
But how can I set the external sound card as default when PulseAudio is used?
The sound card works on another system with the driver "ALSA" without problems. There, however, PulseAudio was uninstalled
www.WT-Radio.de
Man in a van
Thu Jul 25, 2019 7:06 pm
did you install PulseAudio yourself?
This is mine, rpi4b running Buster
[email protected]:~ $ dpkg -s pulseaudio
dpkg-query: package 'pulseaudio' is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files.
Rootinator
Thu Jul 25, 2019 7:09 pm
No, I downloaded a ready-made system and PulseAudio was already preinstalled there.
www.WT-Radio.de
Man in a van
Thu Jul 25, 2019 7:11 pm
Well, do you neeed it/ can you remove it and use ALSA
Man in a van
Thu Jul 25, 2019 7:35 pm
A quick search found this for pulseaudio
https://raspberrypi.stackexchange.com/q ... dio-device
and I have used this on Stretch, not sure it's reaaly needed now. on Buster, but it should work
https://raspberrypi.stackexchange.com/q ... ian-jessie
I think tha main problem is tha your sound card is not being consistently recognised
