hans_ar
RPi 4 - Dual screen in CLI
Wed Jul 17, 2019 1:03 pm
I have read threads about dual screen on RPi4 but i couldnt find info about how to extend screen in CLI. I tried to configure in GUI and then boot into CLI, but i got only mirror.
Can anyone tell me location of config file? Thanks
6by9
Re: RPi 4 - Dual screen in CLI
Wed Jul 17, 2019 1:36 pm
I don't believe Linux allows you to stretch the console framebuffer across two screens. I've never seen it on any install I've ever done. I'm not sure what the gain would be in stretching the screen when at the console.
You can control the two displays independently via libdrm when in the console.
clicky
Wed Jul 17, 2019 1:48 pm
I bet it is possible to have separate consoles on different framebuffers. Last time I was playing with it was for adding additional screens on SPI interface, and assign console to it. I can't remember what I've done then - later I just switched to fbcp and had main (GPU supported) framebuffer just copied to second framebuffer (and run LibGDX without X windows). But, at one point I did set up extra console, somehow, on fb1...
6by9
Wed Jul 17, 2019 1:56 pm
DRM/KMS only exposes one framebuffer though.
X renders direct through DRM (not the framebuffer) therefore it can do what it wants with regard sending images to each display. The console renders to the framebuffer, and that is then rendered through DRM's frame buffer emulation.
hans_ar
Wed Jul 17, 2019 2:11 pm
I need to play one video on two screens with omxplayer, but without GUI. Right now im using PiWall, so for 2 screens i use 3 Rpi's .
6by9
Wed Jul 17, 2019 2:37 pm
The same video on both screens, or different videos?
omxplayer won't allow you to replicate the video on both screens directly, but the underlying components will. At the moment it'll have a video_decode component feeding video_scheduler, and then video_render. Insert a video_splitter after video_scheduler, and create a 2nd video_render for the second screen. If kept with IL (or MMAL) then there are no actual image copies involved at all.
You should be able to achieve the same thing with GStreamer and kmssink. kmssink has a connector-id property which allows configuration of which display is to be rendered to via DRM. Getting those magic numbers really needs to use modetest. They're dynamic numbers, so you either need to enumerate them, or have some mechanism to look them up.
hans_ar
Thu Jul 18, 2019 6:17 am
Thanks for your answer.
I want to play video for example, resolution 3840x1080 on two screens (extended), but in CLI.
Thu Jul 18, 2019 8:55 am
The H264 decoder cannot handle that width - are you planning to do normal 1920x1080 and stretch it?
hans_ar
Thu Jul 18, 2019 9:13 am
Yes, i want to strech it but also i want to play videos with 3840x1080.
Thu Jul 18, 2019 9:55 am
Only the HEVC decoder can do that high resolution, not the H264 decoder. At the moment the HEVC is only reliably available in Kodi, although we are working on that.
hans_ar
Thu Jul 18, 2019 10:14 am
Thank you for your answer, so in GUI I can run strached video?
Thu Jul 18, 2019 10:30 am
Not sure. I think so on the Pi4 but you would need to try it.
6by9
Thu Jul 18, 2019 8:12 pm
Do you actually want the gui? Your earlier comments said not.
From the console you can use drm to display the same plane on both displays but with different source cropping rectangles (this I how x renders a stretched gui) .
Hevc decode is still being developed, so hooking it up to drm will currently be slightly suboptimal, and we don't have any demo code for it.
With X running everything has to run through gl to be rendered, therefore the system load is significantly higher.
