Lucifer22334
Error Updating and Upgrading or installing packages
Wed Jul 17, 2019 10:40 am
Hi all,
I am using 2018 stable version of raspbian stretch with desktop. when I am running
sudo apt-get update It is giving me Error 403 Forbidden[IP: 93.93.128.191 80] so I cant run Sudo apt-get upgrade.
Then I tried to install packages Sudo apt-get install xxxx then also same Error and say unable to fetch packages and above Error.
This same Error was also with the buster image with desktop and recommended software. I tried running sudo apt update -y on it also but same Error.
I changed the source list to old one sudo apt-get update was successful but sudo ap-get upgrade gave me again same Error as above.
Any solution to this?
wh7qq
Re: Error Updating and Upgrading or installing packages
Fri Jul 19, 2019 2:58 am
I've never seen this type of error from an update/upgrade..."403 error" is an http status code that you would get from a web page. Are you working from a terminal window or a browser? These commands must be run from a terminal or a terminal window (hope that isn't too obvious).
Stretch should still be upgradeable although it is now out of date, replaced by Buster. From your post, it sounds like you may have messed up your "sources-list" file so if you can't restore it exactly, your best bet is to download a fresh .zip file of Raspbian_latest and burn it to a fresh uSD card if you have files you want to save on the old one. The new distribution will still run fine on your older RPi but also supports the new RPi 4.
rpdom
Fri Jul 19, 2019 6:47 am
Actually it is an error that you would receive from a web server and apt uses http so that error would be possible if there were a problem. It shouldn't happen though. I suspect one of the mirrors has an issue.
I'd say wait a few hours and try again. If it still fails post the full output of the update command, preferably in [code] tags
Unreadable squiggle
Lucifer22334
Fri Jul 19, 2019 12:15 pm
I was running from the raspberry pi terminal and I haven't changed the source list I just commented it and added latest from the busters source list. Buster was also giving the same error so I thought the move to an older version. I also tried by putting the old source list which I had in my Old raspberry pi, then also the same Error.
Lucifer22334
Fri Jul 19, 2019 12:16 pm
Ok still the same Error I am going to put that in this post but when I can't go scrolling up in the terminal Because only last couple houndreds lines are shown at the end.
rpdom
Fri Jul 19, 2019 2:09 pm
The apt update command shouldn't result in hundreds of lines, just twenty or so at most.
You could always redirect the output to a file.
Unreadable squiggle
Lucifer22334
Fri Jul 19, 2019 2:20 pm
Ok then I will post this tomorrow in this question.
Lucifer22334
Tue Jul 23, 2019 5:35 am
I have Loaded latest raspbian stretch Image on raspberry pi 3 and on sudo apt-get update I have this Error.
Here is the output:
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Ign:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
Ign:4 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
Err:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
403 Forbidden [IP: 93.93.128.193 80]
Fetched 15.0 kB in 31s (481 B/s)
Reading package lists... Done
E: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... f/Packages 403 Forbidden [IP: 93.93.128.193 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Tue Jul 23, 2019 7:24 am
Here is the output:
It would appear you have an internet connection issue, I am able to access both http://raspbian.raspberrypi.org/raspbian & 93.93.128.193
Though considering Stretch has been replaced with Buster it may be prudent to start with a fresh install of Raspbian Buster on a new SD Card ?
RPi 4B 4GB (SSD Boot)..
Lucifer22334
Wed Jul 24, 2019 9:34 am
Here is the output:
Ok I will try that.
Bkrpi
Thu Sep 19, 2019 5:52 pm
i do have the same probleme:
pi@Rpi-server:~ $ sudo apt update
Err:1 http://archive.raspberrypi.org/debian buster InRelease
403 Forbidden [IP: 46.235.227.11 80]
Get:2 http://archive.raspbian.org/raspbian buster InRelease [15.0 kB]
Get:3 http://archive.raspbian.org/raspbian buster/non-free Sources [139 kB]
Get:4 http://archive.raspbian.org/raspbian buster/contrib Sources [78.5 kB]
Get:5 http://archive.raspbian.org/raspbian buster/main Sources [11.3 MB]
Get:6 http://archive.raspbian.org/raspbian buster/main armhf Packages [13.0 MB]
Get:7 http://archive.raspbian.org/raspbian buster/contrib armhf Packages [58.7 kB]
Get:8 http://archive.raspbian.org/raspbian buster/non-free armhf Packages [103 kB]
E: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease 403 Forbidden [IP: 46.235.227.11 80]
E: The repository 'http://archive.raspberrypi.org/debian buster InRelease' is no longer signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
did 3 fresh installs on stretch and buster but no luck. i also tried modifying the source-list.
ShiftPlusOne
Thu Sep 19, 2019 7:23 pm
Running "curl --header "Host: archive.raspberrypi.org" http://46.235.227.11/debian/dists/buster/InRelease" looks okay from here.
