geev03
64 bit Ubuntu 18.04 on Pi4B
Tue Jul 16, 2019 11:08 am
Looking for testing a 64 bit OS on Pi4B? Here is a link to one image that works..https://blog.cloudkernels.net/posts/rpi4-64bit-image/
[email protected]'s password:
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.19.57-v8+ aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
  System information as of Tue Jul 16 10:58:43 UTC 2019
  System load:  2.95              Processes:           111
  Usage of /:   27.4% of 6.99GB   Users logged in:     1
  Memory usage: 24%               IP address for eth0: 192.168.1.172
  Swap usage:   0%
  Get cloud support with Ubuntu Advantage Cloud Guest:
    http://www.ubuntu.com/business/services/cloud
161 packages can be updated.
80 updates are security updates.
Last login: Tue Jul 16 10:47:22 2019
[email protected]:~$ uname -a
Linux ubuntu 4.19.57-v8+ #2 SMP PREEMPT Tue Jul 9 20:31:37 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
bomblord
Re: 64 bit Ubuntu 18.04 on Pi4B
Tue Jul 16, 2019 11:39 am
I won't be able to get to this until much later today but I've been watching out for a working 64 bit image like a hawk and am definitely willing to throw this onto a burner micro SD card to test. Do you have any impressions of it? Does it have a working driver for the VC6? How is performance?
geev03
Tue Jul 16, 2019 1:12 pm
It has its limitations- I can only see 1 GB RAM on this Pi4B-4
As a server , it works as fast as the setup on Raspbian Buster.
Aim was to test docker ,that will take few more steps but without access to the 4GB memory only marginal improvement from docker on Pi3 is expected.
[email protected]:/home/ubuntu# docker
Command 'docker' not found, but can be installed with:
snap install docker     # version 18.06.1-ce, or
apt  install docker.io
See 'snap info docker' for additional versions.
bomblord
Tue Jul 16, 2019 1:17 pm
A 1GB RAM limitation might be a deal-breaker dang... Might still try it
o635789
Tue Jul 16, 2019 4:29 pm
You need to reconfigure:
echo "total_mem=1024" >> config-extra.txt
and bump the number up for your board, then re-build it.
bomblord
Tue Jul 16, 2019 6:41 pm
Anyway to edit the prebuilt image to do that or otherwise do it after installation something like just extracting the file and editing it? I can try to insert that at the appropriate point in the build process in the op but I'm not remotely familiar with building an OS image and tbh those instructions look like greek to me.
o635789
Tue Jul 16, 2019 9:04 pm
My bad, it actually won't work. The memory limit is likely in Raspberry's firmware, it happened once when Raspberry Pis increased RAM to 1GB in the past.
bomblord
Tue Jul 16, 2019 9:11 pm
Dang that sucks oh well might have to hold out then...
hardwaremack-orginal
Tue Jul 16, 2019 9:27 pm
this is pretty exciting!!!!
i am DLING this now. will use the lazy image.
i have 2gig PI4B so i will just make that edit.
no big deal.
Charles
bomblord
Wed Jul 17, 2019 12:29 am
Well it "works" but I sadly can't any form of GUI to properly install. After installing the Ubuntu desktop environment I only get a mouse.
magnusbrzenk
Wed Jul 17, 2019 12:41 am
Are there any 64-bit distros out yet that can take full advantage of Pi 4B's 4GB?
bomblord
Wed Jul 17, 2019 1:36 am
Not yet just got to be patient for now.
geev03
Wed Jul 17, 2019 9:47 am
Responses of remote GUI is not that bad...
bomblord
Wed Jul 17, 2019 12:09 pm
The kind of software I'm wanting to run and wanted a 64 bit environment for wouldn't be very well suited for remote desktop (games, emulation)
Nifnat
Wed Jul 17, 2019 4:01 pm
When I tested it out about a week ago the Ubuntu Desktop didn't want to work properly. If you switch between virtual consoles and then back to the desktop you should be able to get to the logon screen but it's very slow. The Lubuntu desktop seems to work fine for the most part if you want to try that out.
Also the latest kernel seems to have fixed some of the DMA issues, now allowing you to use more than 1GB of RAM. I've currently got a Lubuntu 18.10 environment booting and usable with 3GB of RAM
Musketeer
Wed Jul 17, 2019 4:23 pm
Definitely use Lubuntu, Ubuntu is memory hog kindda and sortta... + they stopped use icons on desktop!
Linux is like woman - both wants 180 % of your time...
You want speed Java 9.8x? Throw it out of some Window(s)!
My girlfriend is terribly unmature - she always sinks my boats in bathtub!
bomblord
Wed Jul 17, 2019 6:03 pm
Do I just need to run update/upgrade to get that fix or build it using something else? Going to try this out tonight.
Nifnat
Wed Jul 17, 2019 6:08 pm
You'd either need to build the kernel yourself or wait for somebody else to build it and then upload it.
bomblord
Wed Jul 17, 2019 6:16 pm
You'd either need to build the kernel yourself or wait for somebody else to build it and then upload it. There's a post explaining how to build a kernel for the Pi4 on this forum that might be useful to you.
I'll see what I can figure out. Can I use the instructions in the OP and just swap it for an armv8 ubuntu 18.10 image?
Nifnat
Wed Jul 17, 2019 6:35 pm
You could do that. I'd think that the 18.04 image should work fine as well. Looks like the instructions in the OP is pulling in the latest kernel so it should build the one with the fixes just fine.
gilius2k15
Thu Jul 18, 2019 8:46 am
This is a great start - the lazy image even has KVM enabled!
Could you guys please share your exact terminal commands to get any kind of GUI? I tried sudo apt install lubuntu - but it doesn't find any such package. Should a repository be set first?
I tried sudo apt install lxde - but just got a mouse cursor.
Now I've upgraded to 18.10 - kind of ends prematurely - and now I'm trying lxde again.
bomblord
Thu Jul 18, 2019 2:51 pm
Could you detail what you did to get the 18.10? I searched all their repositories that I could find and couldn't find an armv8 build of it.
gilius2k15
Thu Jul 18, 2019 3:21 pm
18.04 > 18.10
Download this and write to Micro SD card: (login: ubuntu/ubuntu)
https://cloudkernels.net/ubuntu-18.04.2 ... kvm.img.xz
Then make sure you have update-manager-core package installed.
sudo apt install update-manager-core
Next, edit a configuration file using nano or your preferred command line text editor.
sudo nano /etc/update-manager/release-upgrades
At the bottom of this file, change the value of Prompt from lts to normal.
Prompt=normal
Save and close the file. After that, run the following command to begin the upgrade process.
do-release-upgrade
But I still cannot get the GUI to work - just shows a black screen with white mouse cursor.
I tried LXDE, Mate, Xubuntu so far.
bomblord
Thu Jul 18, 2019 3:35 pm
18.04 > 18.10
Prompt=normal
do-release-upgrade
Awesome, thank you I'm going to begin poking around and see what I can figure out as far as the GUI goes.
bomblord
Thu Jul 18, 2019 5:41 pm
Currently on my 5th re-image have tried installing lubuntu-desktop both before and after the upgrade (also of note the upgrade always ends in a critical failure on flash-kernel but still upgrades some stuff). I either get a dependency error or otherwise just can't find it. I tried gnome and mate as well and they don't work either. Going to try a different approach.
Edit 2 hours and a lot of changes later got lubuntu to install but even that just ends up with a black screen and a mouse. Looks like I'm just going to be waiting for an official 64 bit image from one of the Linux distro devs.
Return to “Ubuntu”
