careyjames
SD Card Copier program, where is it located in the archive?
Mon Jul 15, 2019 11:47 pm
Hello!
The SD Card Copier program, where is it located in the archive? I've been digging through:
https://archive.raspberrypi.org/debian/pool/main/
and looked in my raspbian in /var/cache/apt/archives
I love this program because it can take a live running Linux os like raspbian and clone it out to a fully bootable backup. one shot, one kill.
A. is there a .deb file for this utility so i can use it in another os on my pi like kali?
B. would it work the same in another Debian os getting everything?
thanks
betta fsck yourself before you wreck yo self.
trejan
Re: SD Card Copier program, where is it located in the archive?
Tue Jul 16, 2019 12:07 am
No idea how portable this is.
$ apt-cache show piclone
Package: piclone
Version: 0.13
Architecture: armhf
Maintainer: Simon Long <[email protected]>
Installed-Size: 66
Depends: libc6 (>= 2.7), libglib2.0-0 (>= 2.31.8), libgtk2.0-0 (>= 2.24.0), parted, dosfstools, e2fsprogs, coreutils, mount, uuid, zenity, dbus-x11
Priority: optional
Section: utils
Filename: pool/main/p/piclone/piclone_0.13_armhf.deb
SHA256: 9405809fec8141f5d10dd595bf24e1755fe38bed266c2e113a425f9239ec30eb
SHA1: 1503567ab7830b61c59bee5bd46b0fa5bbed6f24
MD5sum: 6a41a0b1ac48c59829a9dc87c31e14e3
Description: SD Card backup program for Raspberry Pi
This is a GTK application to copy the contents of SD cards and other USB
drives. It mirrors the partition layout of the source device onto the
target device, with the exception of the last partition, which is created
to be the largest which will fit onto the target device.
Files are then copied between all partitions - the result should be a
bootable card with an image of the source device.
Description-md5: d354cef5bfba3a8590773f87a3a778fc
careyjames
Tue Jul 16, 2019 12:41 am
aaaahhh piclone ha ha
i got raspi-config over there the same way, ill let you know if it works.
thanks!!!!
klricks
Tue Jul 16, 2019 1:31 am
thanks!!!!
You might want to review the desktop entry. In the command field there is a call to a .sh shell script among other things.
Right click on [SD Card Copier] in the menu and choose [Properties]
raspi-config only works in Raspbian.
careyjames
Tue Jul 16, 2019 5:05 pm
i did get raspi-config to work just fine in kali, are you telling me from experience that there is going to be a nasty surprise in one of the menus that i don't know about???
and then, there is this, an even further tweak to raspi-config for kali users:
https://github.com/Re4son/RPi-Tweaks/tr ... ipi-config
the sd card copier worked but with issues, it did copy to a sd card while running in a live system, and it did boot the copy but it went straight to command line and then startx rendered a wierd cutout version of desktop with no text or icons...
I'm going to check out trying to find the shell script you mentioned.
