Daryls.Produce
Raspberry Pi Won't Update
Mon Jul 15, 2019 8:52 am
Hi Community:
When I do an
sudo apt-get update
I get a message
E: Repository 'http://raspian.raspberrypi.org/raspian buster InRelease' changed its value from 'testing' to 'stable'
N: This must be accepted explicit before updates to this repository can be applied. See apt-secure(8) manpage for details
So, I looked at teh apt-secure manpage.... and it may as well have been written in Latin: I do not understand it and don't know how to fix the problem of not being able to update.
Can somebody please instruct me how to fix this?
Thank you!
Daryl
Robbo
Re: Raspberry Pi Won't Update
Mon Jul 15, 2019 8:55 am
Try "apt update" instead of "apt-get update". It will ask you the question if you want to update.
Mon Jul 15, 2019 8:56 am
Hi Community:
When I do an
sudo apt-get update
I get a message
Thank you!
Daryl
That is not the full message, at the bottom it has a yes / no option, type yes and press enter key
sudo apt update
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Pie_with_Berries
Mon Jul 15, 2019 10:57 am
Try this command:
apt-get update --allow-releaseinfo-change
It worked for me. :)
Original Source:https://www.raspberrypi.org/forums/view ... N#p1497285 From:PeTerO
Don´t worry!! I´m Profesional! 8-)
Daryls.Produce
Mon Jul 15, 2019 5:20 pm
Thank you for your responses! Both suggestions worked!
Next time you are out here drop by the stand!
Daryl
Daryl's Rural Roadside Honor System Vegetable Stand and Occasional Dairy Produce
Daryls.Produce
[SOLVED]: Raspberry Pi Won't Update
Mon Jul 15, 2019 5:22 pm
This discussion is SOLVED.
trejan
Mon Jul 15, 2019 5:32 pm
They ran apt-get update which doesn't prompt you. apt update does. They're not the same command as the options differ depending on which one you run.
apt --help wrote:It provides the same functionality as the specialized APT tools, like apt-get and apt-cache, but enables options more suitable for interactive use by default.
Mon Jul 15, 2019 7:07 pm
Doh! that is why I listed the apt command in response. APT is better IMO and these days always use in Linux Debian or Debian based Distros............
