forgot the password.
Posted: Wed Jul 10, 2019 10:19 am
by amitg1993
I have forgotten the raspberry pi 3 b+ password. how do I recover it or set a new one. I tried the method where cmdline.txt is edited and "init=bin/sh" is added at the last. But after that when i try "mount -o remount,rw /", I get an error of "mount: can't find PARTUUID=3259521a-02". How do i solve this ???
Re: forgot the password.
Posted: Wed Jul 10, 2019 10:32 am
by epoch1970
Does "mount -o remount,rw /dev/mmcblk0p2 /" work better?
This assumes you're using Raspbian where the root filesystem is in the second partition "p2", the boot FAT partition being "p1"
If you're running Noobs or something else the above command won't probably work. Perhaps " fdisk -l" can show the list of partitions, and you can then find which one you need to mount. See also if "blkid" returns something useful.
EDIT. Sorry. Fixed devices names, thank you rpdom.
Posted: Wed Jul 10, 2019 10:44 am
by rpdom
FTFY
Posted: Wed Jul 10, 2019 11:21 am
by amitg1993
I am new to raspberry....So I don't understand much about filesystem. I tried fdisk -l, i got "cannot open /dev/ram0....15: permission denied" and last entry is "/dev/mmcblk0: permission denied" .i can give you outputs of the commands you want. help me with it.
Posted: Wed Jul 10, 2019 11:30 am
by epoch1970
Check your cmdline.txt file, it should include "init=/bin/sh"
(forward-slash bin forward-slash sh)
Then boot and try the mount command above.
Posted: Wed Jul 10, 2019 11:51 am
by amitg1993
Tried it, still getting cant find PARTUUID. While booting there is one message displayed which says "/bin/sh: 0: can't access tty: job control turned off", Is it because of that message.
Posted: Wed Jul 10, 2019 12:16 pm
by epoch1970
You can disregard the "job control turned off" message, it is unimportant.
Again. Try exactly this command
It will not speak to you about a partition UUID.
This command is ok if you have installed Raspbian.
What system have you installed?
Posted: Thu Jul 11, 2019 6:31 am
by amitg1993
I have raspbian installed...Above command worked, I was able to change the password. Can you explain in short what we actually did ??
Posted: Thu Jul 11, 2019 6:40 am
by rpdom
Firstly, adding init=/bin/sh to cmdline.txt makes the Pi boot with a very restricted environment. It is automatically logged in as the "root" super user. Also, the main file system is set to read-only mode, which means you can't change any files.
The command
tells Linux to change the file system (on /dev/mmcblk0p2, which is the second partition of the SD card) to rw or read and write mode.
"mount" is the command to make a file system available.
"-o" means "with the following options"
The "remount,rw" options mean update the existing system with Read/Write access.
"/dev/mmcblk0p2" is the device name of the main file system.
"/" is where that file system is "mounted".
Posted: Thu Jul 11, 2019 7:33 am
by amitg1993
The command
ohkkk... thank you very much !!
Posted: Thu Jul 11, 2019 7:37 am
by epoch1970
... and you can contrast that with the command you tried at first:
Where the device name is missing. So to try and comply with the command, mount looks up file /etc/fstab which, by convention, contains information for mounts.
In your case, fstab found a device specification matching the “/“ filesystem, referred to as PARTUUID=...
For a reason I ignore, but possibly related to the very minimal environment you’re running off due to init=/bin/sh, mount was unable to make something of that information.
So we replaced that useless information with the name of the device holding the root (“/“) filesystem we, Raspbian users, all know by heart (more or less...): /dev/mmcblk0p2
With the long-form command, mount did not need lookup /etc/fstab, and executed the remount.
And after that, success was at hand. Well done, all.
Posted: Thu Jul 11, 2019 11:54 am
by amitg1993
oohkkk !!
