[SOLVED] Buster 'apt-get update' issue
Posted: Mon Jul 08, 2019 2:16 pm
by hippy
pi@Pi3B:~ $ sudo apt-get update
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [205 kB]
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Nothing in 'man apt-secure' seemed to tell me what to do - So what exactly do I have to do to make things work ?
Re: Buster 'apt-get update' issue
Posted: Mon Jul 08, 2019 2:28 pm
by trejan
Debian Buster was released so it changed to stable.
Run "sudo apt update --allow-releaseinfo-change" and it'll update it.
Posted: Mon Jul 08, 2019 2:29 pm
by MrEngman
Re: [SOLVED] Buster 'apt-get update' issue
Posted: Mon Jul 08, 2019 2:59 pm
by hippy
Thanks. "sudo apt-get update --allow-releaseinfo-change" fixed it for me.
I hadn't seen an Unread Post mentioning it, and a search found nothing obvious. I guess Sod's Law, or Search Fu Failure, given searching now finds a number of threads referencing the issue.
Posted: Mon Jul 08, 2019 7:44 pm
by uilfut
I was stuck too, and found the answer here - so thanks for asking!
Posted: Tue Jul 09, 2019 9:10 pm
by Dan1jel
I too had problem with this and was stuck. Thank you for the solution. And thank you OP for starting this thread.
Posted: Tue Jul 09, 2019 9:20 pm
by hardwaremack-orginal
would of been nice if inside the app it would have said something like type * sudo apt update * if you would like to continue. Thank goodness for this forum.
Posted: Thu Jul 11, 2019 3:38 pm
by ibshar
Thank You
Posted: Fri Jul 26, 2019 8:21 pm
by Juanca
Hi!
Thanks Trejan for your answer :!:
Rgrds
Posted: Wed Jul 31, 2019 2:31 pm
by Ireneos
Thanks. Resolved it on pi 4 (that had new noobs card!)
Posted: Sat Sep 28, 2019 9:13 pm
by miaran
Thanks!
Running sudo apt-get update --allow-releaseinfo-change in the terminal solved it for Raspberry pi 4
Posted: Wed Feb 12, 2020 7:47 pm
by thorstenhirsch
I also (soft) bricked mine when upgrading from stretch to buster, probably because /boot was only ~65MB. Later I figured out that /boot only contained 3 files after the failed upgrade, so I couldn't boot anymore. Here's what one can do in situations like these:
- resize partitions with gparted (or whatever tool you prefer); I shrinked the ext4 root partition by 200MB at its beginning, so that I could enlarge the fat /boot partition by 200 MB
- mount sd card's /boot on /mnt/sd
- download the latest raspbian image
- check the contents of the image: fdisk -l *.img
- mount the image's boot partition with the offset that fdisk just told you: sudo mount -o loop,offset=$((8192*512)) *img /mnt/image
- copy all files from the image to the sd card: sudo cp -a /mnt/image/* /mnt/sd/
- edit /mnt/sd/cmdline.txt, you need to fix "root=..." with something that works, e.g. "root=/dev/mmcblk0p2"
Finished. Now umount everything and try booting. If there's no video signal and green/red LEDs are on, but don't flash, the kernel isn't found, so you still have a problem with /boot. If the video signal is there, but you only see 3 or 4 images of raspberries, then the kernel is being loaded, but "root=..." is wrong and you need to fix cmdline.txt.
