altanhaligur
Update Error
Mon Jul 08, 2019 9:06 am
sudo apt-get update
Get:1 http://archive.raspbian.org/raspbian jessie InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
E: Repository 'http://archive.raspbian.org/raspbian jessie InRelease' changed it s 'Suite' value from 'oldstable' to 'oldoldstable'
N: This must be accepted explicitly before updates for this repository can be ap plied. See apt-secure(8) manpage for details.
What should i do?
rpdom
Re: Update Error
Mon Jul 08, 2019 9:18 am
This has been mentioned in another post. It is the first time I have encountered this issue on a Debian based system.
One solution (Thanks to PeterO), is to use
sudo apt-get update --allow-releaseinfo-change
Which will stop the issue from reoccurring.
You should only need to run that once. After that the mormal
sudo apt-get update
should be sufficient.
Unreadable squiggle
Re: Update Error
Deleted.
I'll do your homework for you for a suitable fee.
rpdom
Re: Update Error
Mon Jul 08, 2019 9:20 am
The pragmatic answer is upgrade to Buster on a new SDCard then move your programs & data over from the retired & unsupportable OS.
Dougie. Please read the posts. This is happening if you already have Buster.
Unreadable squiggle
Re: Update Error
Mon Jul 08, 2019 9:26 am
Sorry I read it as Jessie.
Buster updates were working ok for me yesterday when I was rebuilding my server with Buster (postfix, MariaDB, apache2, Mosquitto, php7.3) on the backup hard disk partition.
It also worked on my PiAware ADSB server which I cut-over to Buster at 22:45 last night.
SimUK
Re: Update Error
Mon Jul 08, 2019 10:44 am
Elektrik
Re: Update Error
Mon Jul 08, 2019 11:42 am
Just run:
sudo apt-get clean all
sudo apt-get update
