Musketeer
How fast is your external HDD/SSD through USB3 reduction on Pi4?
Sun Jul 07, 2019 2:50 pm
Which reduction you use? Stability + other problems is important too of course?
Linux is like woman - both wants 180 % of your time...
You want speed Java 9.8x? Throw it out of some Window(s)!
My girlfriend is terribly unmature - she always sinks my boats in bathtub!
clicky
Re: How fast is your external HDD/SSD through USB3 reduction on Pi4?
Sun Jul 07, 2019 3:21 pm
As I have already posted before:
$ sudo hdparm -tT /dev/sda1
/dev/sda1:
 Timing cached reads:   1812 MB in  2.00 seconds = 905.89 MB/sec
 Timing buffered disk reads: 750 MB in  3.00 seconds = 249.94 MB/sec
Which pretty much translates to 2Gbit/s (https://www.ebay.co.uk/itm/USB-3-0-To-C ... 3307890492 + old Intel's Series 320 80GB SSD).
I've got Intel's SSD6, M.2 512GB SSD waiting appropriate enclosure to try it out, too...
pik33
Sun Jul 07, 2019 8:00 pm
My USB3 enclosure with SSD inside is incompatible with Pi4 USB3 (driver) - 11 Mbps only - I started another topic and have a little or rather no hope it can be fixed after reading explanations.
clicky
Tue Jul 16, 2019 4:13 pm
:D
$ sudo hdparm -t /dev/sdb
/dev/sdb:
SG_IO: bad/missing sense data, sb[]:  70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 Timing buffered disk reads: 1058 MB in  3.00 seconds = 352.55 MB/sec
Read it as 2.8 Gbit/s. (Edited - someone forgot decimal point :roll: )
It is done with Intel's M.2 512GB SSD with USB3.1 TO PCI-e NVMe SSD enclosure. Main thing was to pick correct USB cable (USB3 to USB C - I've got a few USB C which were really USB2 only).
That's the fastest anyone reported here so far...
RaTTuS
Contact: Twitter YouTube
Tue Jul 16, 2019 4:19 pm
https://www.raspberrypi.org/forums/view ... 3&t=245931 does this help
Covfefe
clicky
Tue Jul 16, 2019 8:25 pm
:D
/dev/sdb:
Actually - this might be the answer to this thread's question (not necessarily the most correct one though):
Just before I reformated SSD as ext4, I tested it on my mac and it read over 600MB/s in comparison to 350MB/s on RPi. Same SSD, same enclosure - only different thing was usb-c/usb-c cable used on mac and usb-c/usb-3 cable used on RPi (and it is usb3 for sure - I checked that there are 5 extra pins deep in the connector).
So, 350MB/s (2.8Mbit/s) limit in this case is due hardware/software on RPi as SSD (and enclosure) is able to deliver almost twice as much in some other circumstances. If theoretical throughput is supposed to be 4Gbit/s it would be over 40% overhead which seems a bit excessive.
MisterEd
Tue Jul 16, 2019 10:29 pm
How do you pick the correct USB cable?
HawaiianPi
Tue Jul 16, 2019 10:52 pm
Just make sure it is a USB 3.0 compatible cable.
Some USB-A to USB-C cables are "charge" cables, and many of those only support USB 2.0 data speeds.
clicky
Wed Jul 17, 2019 9:27 am
First clue is that it is 'blue' inside the connector. Second is when you look down the pins of USB A side, you'll see another 5 pins between (and around) original 4 deeper in the connector. BTW as HawaiianPi said :)
313Alf
Wed Jul 17, 2019 1:17 pm
I tried this myself out of interest, but not sure how to convert to GBit/s. My system:
Pi-4B 4GB
Intel 520 series 120 GB SSD
'Cable Matters' 1metre USB 3.0 Type A to Micro B cable
Orico 2139U3 (R1.0) enclosure:
pi@raspberrypi:~ $ sudo hdparm -tT /dev/sda1
/dev/sda1:
 Timing cached reads:   1636 MB in  2.00 seconds = 818.30 MB/sec
 Timing buffered disk reads: 968 MB in  3.00 seconds = 322.18 MB/sec
