FeepingCreature
Re: Toolchain
Thu Jan 19, 2012 4:23 pm
A couple of dev-related questions?
What are the appropriate flags for gcc-configure (--target), gcc, as (-meabi) to build code that will be binary-compatible to the eventual default image for the RazPi?
Are the Broadcom GLES drivers API-compatible with MESA compiled for GLES/EGL?
Is there any chance you could make a "queue up for shell access to an actual razpi" thread, so we can test our programs before the release hits?
Re: Toolchain
Thu Jan 19, 2012 4:59 pm
I used the following when doing some basic benchmarking -O3 -mfloat-abi=softfp And yes, I think the API to the GL libraries is the same as MESA. It's designed to be a drop in replacement for the software renderer.
FeepingCreature
Re: Toolchain
Thu Jan 19, 2012 8:01 pm
Thanks. Related question. I have this GLES test code: http://paste.pocoo.org/show/537361/
When I compile it for x86 (Mesa/i965), it renders a red window as expected. When I attempt to run it in qemu, it just renders a white window. Any idea what the problem could be?
spennig
Re: Toolchain
Thu Jan 19, 2012 8:12 pm
Perhaps qemu does not emulate the necessary 3d hardware?
richard77
Re: Toolchain
Thu Jan 19, 2012 8:38 pm
I use gentoo, which is a source based distribution, and the documentation discourage to use -O3 since it can produce not working binaries and it tends to give bigger code, reducing cache efficiency , so often the code is actually slower compared to -O2. On processors with small cache, -Os gives better performances. Anyway, I plan to get on R-Pi, probably at the second batch and I hope to install Gentoo on it and will test and report.
Re: Toolchain
Thu Jan 19, 2012 10:01 pm
On the tests I was doing it did help quite a bit, but it will depend - the  programs I tested were pretty small anyway. All the binaries worked anyway!
There was another setting I failed to use when I was doing my builds that made things a lot faster, and I appears not to have noted it down - sorry.
-mcpu=arm1176jzf-s
might help as well.
