- JoelHinson
USB as priamary audio
i have tried many online solutions at this and had success with a previous model at this,.. i have a USB audio card and i would like to make that the default audio selection. with sound tests for sure it is working, however to prioritize "pcm" and "ctl" as "1" in the "/usr/share/alsa/alsa.conf" is not getting it done,.. is there a statement that is negating i am wonder?? a thing that knocks it back down to less than the defualt choice,... i believe i have a "model 3",.. what is the best/ sure fire technique at naming the USB as default audio at start up? can anyone say for sure what does work?
Re: USB as priamary audio
What OS and version are you using?
On my RPi3B with Raspbian Stretch with Desktop, I can do that on the top panel where the speaker icon resides.
Right clicking it, selecting the audio device, then rebooting will set it.
Some people be like:
- JoelHinson
i am away from it right now, over at my sisters celebrating the holiday,..i am thinking it is 3?? the desktop looks like this (see attach),.. could you screenshot what you are talking about,.. thank and you if you could.
- Attachments
- IMG_20190704_173849.jpg (109.97 KiB) Viewed 1098 times
- JoelHinson
it works here and there,.. except where i want it to work which is a program "puredata"/"pd",.. that program gives this error:
ALSA input error (snd_pcm_open): No such file or directory
ALSA output error (snd_pcm_open): No such file or directory
so then within this program i have toggled every option and no sound ,.. apparently ,...neither "in" nor "out" of the card
- JoelHinson
just to keep this fresh anyone have puredata/ pd? is there an update or another thing recommended to install that works out the bugs? has anyone else seen this error? like i said there is a drop down "media" and that lists all of the sound options and i toggled through all of them and still this error persists.
Man in a van
Have you tried ?JoelHinson wrote: ↑Thu Jul 04, 2019 8:01 pmbelieve i have a "model 3",.. what is the best/ sure fire technique at naming the USB as default audio at start up? can anyone say for sure what does work?
Open Terminal
Sudo nano /boot/config.txt"dtparam=audio=on"
dtparam=audio=on- JoelHinson
man in van, that didnt do the trick,.. thanks for the info though. same "load error" happening with the program
Man in a van
That's a shame. Did you save and reboot after commenting out the line?
Well we can try this approach. First chect if the usb is present.
Open a terminal and type (this is my rpi4B with Buster)
Device 3 is my usb dac
and then type
this is a snip
we can see the usb dac is recognised.
There are a couple of ways to go now, It might be best to try this on a backup copy first, just incase.....so try this first.
This is a spoof sheet that I use, I copied it from a posting on the web, but can't now find the link to credit the original author.
I hope it is clear: I'm still using the rpi4B, but I have done this on rpi3B and 3B+ on Stretch.
First of all, check to see what order your cards have been loaded in:
Counting cards begins from 0 so the default bcm2835 is loaded first and my USB card is loaded second.
To reorder my cards, I first create a file named /etc/modprobe.d/alsa-base.conf. It can be named anything you want as long as it ends with .conf.
I then paste this into alsa-base.conf
Save and exit with
Ctrl+x, y, Enter
and check that the cards have been reordered
I have found that with some usb dacs it works if i post the output from
examples are:
ronnie
lsusbCode: Select all
pi@raspberrypiLMS:~ $ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 20b1:000a XMOS Ltd
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root huband then type
lsmodCode: Select all
pi@raspberrypiLMS:~ $ lsmod
Module Size Used by
fuse 110592 3
rpcsec_gss_krb5 32768 0
rfcomm 49152 4
snd_usb_audio 192512 2
pi@raspberrypiLMS:~ $There are a couple of ways to go now, It might be best to try this on a backup copy first, just incase.....so try this first.
$ cat /proc/asound/modules
pi@raspberrypiLMS:~ $ cat /proc/asound/modules
0 snd_bcm2835
1 snd_usb_audio
pi@raspberrypiLMS:~ $To reorder my cards, I first create a file named /etc/modprobe.d/alsa-base.conf. It can be named anything you want as long as it ends with .conf.
cd /etc/modprobe.d
sudo touch alsa-base.conf
sudo nano alsa-base.confCode: Select all
# This sets the index value of the cards but doesn't reorder.
options snd_usb_audio index=0
options snd_bcm2835 index=1
# Does the reordering.
options snd slots=snd_usb_audio,snd_bcm2835Save and exit with
Ctrl+x, y, Enter
sudo rebootCode: Select all
cat /proc/asound/modulesI have found that with some usb dacs it works if i post the output from
aplay -Land another# This sets the index value of the cards but doesn't reorder.
options snd_soc_iqaudio_dac index=0
options snd slots=snd_soc_iqaudio_dac,snd_bcm2835
I hope you have better luck this time, remember to maybe try it on a copy first.# This sets the index value of the cards but doesn't reorder.
options snd_soc_allo_digione index=0
options snd slots=snd_soc_allo_digione,snd_bcm2835
ronnie
- JoelHinson
my lsmod is throwing a fit? does this look like the issue?
- Attachments
- IMG_20190706_064753.jpg (46.5 KiB) Viewed 934 times
- IMG_20190706_064705.jpg (129.94 KiB) Viewed 934 times
- IMG_20190706_064622.jpg (151.29 KiB) Viewed 934 times
Man in a van
Man in a van
So I did a quick search and came up with this, the ID matches yours 1b3f:2008
https://learn.adafruit.com/usb-audio-ca ... cm108-type
a further google finds
https://raspberrypi.stackexchange.com/q ... nc-to-work
which is 2007 (so similar)
maybe update the firmware?
I'm sorry but I will have to leave this now.
Keep us posted on your progress and I'll and help further If I can. Maybe someone else (with the card) will drop in.
ronnie
look at this?
https://learn.adafruit.com/usb-audio-ca ... lsa-config
ronnie
look at this?
- JoelHinson
its one of these.,..the device makes sound,.. just not with a particular program "pure data". i will look over your posts.
thank you for all your time on this "man in van",.. i found the correct combination,.. for one of these usb adapters running with "pure data" ,.. in the "media" drop down you select "portaudio" and then set it to "default" and then "save all settings".
- Attachments
- IMG_20190706_184802.jpg (86.28 KiB) Viewed 879 times
Man in a van
Glad your sorted.
