gennargiu
Heatsinks official for rpi 4 ?
Wed Jul 03, 2019 11:30 am
hello I wanted some advice on which heatsinks to buy for my new rpi4 with 4 gigs of ram, as I saw that those used for rpi3 do not respect the measures of the new board (cpu + ram) thanks :roll:
gennaro
Raspberry Pi3 Starter Kit
RaTTuS
Contact: Twitter YouTube
Re: Heatsinks official for rpi 4 ?
Wed Jul 03, 2019 11:31 am
Covfefe
jahboater
Wed Jul 03, 2019 11:53 am
There is no "official" heat sink.
I like this one:-
https://thepihut.com/products/al-heat-s ... 30-30-10mm
Its actually heavier than the Pimoroni one and has proper 3M-8810 thermal tape.
See also the aluminium cases from FLIRC and KODI.
gennargiu
Wed Jul 03, 2019 12:06 pm
https://shop.pimoroni.com/products/rasp ... 4-heatsink
or get a 35x35mm one from anywhere
many thanks
gennargiu
Wed Jul 03, 2019 12:11 pm
I like this one:-
but isn't it small for rpi4? I mean to use it on the cpu or on the ram that on the new rpi4 is rectangular in size :roll:
Raspberry Paul
Wed Jul 03, 2019 1:29 pm
Pimoroni were saying their heat sinks only drop the CPU temp by 2 degrees.
I'm using their FanShim and it's dropped the temp by 30 degrees. Low profile and quiet.
https://shop.pimoroni.com/products/fan-shim
http://www.raspberrypaul.co.uk
Gomoto
Wed Jul 03, 2019 1:31 pm
I dont bother what kind of tape my heatsink has got. As soon as I put it on my Pi 4 I burned my finger ;)
Heat transfer is obviously very good :twisted:
jahboater
Wed Jul 03, 2019 4:32 pm
In the past some Pi heat sinks came with tape that was an insulator :(
rpdom
Wed Jul 03, 2019 4:47 pm
I haven't got any heatsink or fan on my caseless (no cases available at the time) Pi 4B.
Running apt-get dist-upgrade took it up to 100% on one cpu core for several minutes and it hit 64°C in ambient 21°C. Gently waving a smallish piece of card over it to get a slight airflow reduced that to 54°C and when idle it went down to 46°C.
Unreadable squiggle
wren
Wed Jul 03, 2019 4:55 pm
This is the only set I've seen specifically for the Pi4.
https://www.canakit.com/raspberry-pi-4-heat-sinks.html
gennargiu
Wed Jul 03, 2019 5:24 pm
many thanks ;)
hardwaremack-orginal
Wed Jul 03, 2019 5:33 pm
the official case should come with a small fan / vents in case.... and a HS.....
Imperf3kt
Wed Jul 03, 2019 7:23 pm
Thats the lowest temperature I've seen reported for a PI4b so far, even Jamesh claims his Pi runs at 55 degrees with the additional use of the POE hat fan, up to 80 degrees without the fan.
55:55:44:44:4C
52:4C:52:42:41
rpdom
Wed Jul 03, 2019 7:36 pm
Hey, what can I say. I'm just the coolest :-)
Unreadable squiggle
jbeale
Wed Jul 03, 2019 8:18 pm
FWIW: you can describe how good a heatsink is with the thermal resistance measured in degrees C per watt (or K/W but Centigrade and Kelvin degrees are the same size). This means thinking of the heat flow from the source (inside the SoC chip) to ambient air just like an electrical current passing through a series of resistors, where each resistor has a voltage drop across it corresponding to a temperature difference (delta-T) through each part eg. from chip to package, package to heatsink, and heatsink to air. Unless you have bad or no thermal paste/tape, by *far* the largest thermal resistance in the chain is the last one, from the fins on the surface of the heatsink to the air, so that determines the entire performance. If you have perfectly still air, it is a very good insulator and even a large heatsink is nearly useless (at least for a steady-state thermal load). Fortunately heat causes convection and there will be some air motion even inside a closed case- but not very much! A bigger case helps, an open/vented case is better, a heatsink built into or extending through the case is better yet, and of course a fan for forced air best of all.
Wed Jul 03, 2019 8:41 pm
Up to 85 under load. Think it was actually 45-55 with the PoE HAT depending on load.
ejolson
Thu Jul 04, 2019 3:21 am
gennaro
I suggested in this post that an official heatsink be developed for the Pi 3B+ last year. At that time people also suggested that official holes in the official case would also help. I think many people would purchase an official heatsink, especially if it had a distinctive raspberry design. Currently, the closest thing to an official thermal management solution is the built-in fan on the power-over-Ethernet hat.
Gavinmc42
Thu Jul 04, 2019 4:39 am
Just about anyway seems to help.
Heatsink only, fan only or both.
Even sideways mounting helps.
The amount of cooling required seems to be quite small to drop 10-15 degrees.
Enclosing in a case makes it go up as that reduces air circulation.
What is the smallest fan/heatsink combo available?
I'm dancing on Rainbows.
gennargiu
Thu Jul 04, 2019 6:39 am
I ordered the pimoroni heatsink, I wanted to ask you before using it, looking from the photo on the manufacturer's website I see that the same cannot cover all the part concerning the raspberry pi 4 ram, can this cause rpi4 problems? And another thing always seeing from the photo as it is highlighted the heatsink does not create problems to the connection placed on the left side? thank you for your possible answers
gennaro
jahboater
Thu Jul 04, 2019 8:17 am
The top of SoC heat spreader is higher than the memory and the rf shield. Your Pimoroni heat sink will cover them, but not cool them. That's one reason why I chose the smaller PiHut heat sink (which is also heavier and has taller fins).
jahboater
Thu Jul 04, 2019 8:19 am
I have found with all Pi's that the best convection cooling is with the Pi board on edge. The same is true if a heat sink is fitted, but of course the fins should be aligned with the airflow. That is vertically.
ejolson
Thu Jul 04, 2019 1:23 pm
I find it interesting that a heatsink intended for passive use optimally has a different design than one originally intended to be used with a fan. A picture of such a heatsink and explanation of its design may be found at the end of this page.
Gavinmc42
Sat Jul 06, 2019 3:49 am
Wonder if we can get some nice red anodised raspberry shaped heatsinks?
Stick a safety pin on the back and we have Raspberry Pi badge for the swag shop?
Earring Pi heatsinks?
chipace
Sat Jul 06, 2019 5:47 am
I'm using Adafruit's 15x15x15mm heatsink.
https://www.adafruit.com/product/3082
Using this method (a53 with 4 processes):
https://core-electronics.com.au/tutoria ... ry-pi.html
pi@raspberrypi:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& stress -c 4 -t 100s
[1] 1507
stress: info: [1508] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd
  • frequency(48)=600169920
    temp=43.0'C
    frequency(48)=1500345728
    temp=50.0'C
    temp=53.0'C
    temp=54.0'C
    temp=55.0'C
    frequency(48)=1500398464
    temp=56.0'C
    temp=56.0'C
    temp=58.0'C
    temp=59.0'C
    temp=60.0'C
stress: info: [1508] successful run completed in 100s
gennargiu
Sat Jul 06, 2019 6:33 am
[1] 1507
    temp=43.0'C
    temp=50.0'C
    temp=53.0'C
    temp=54.0'C
    temp=55.0'C
    temp=56.0'C
    temp=56.0'C
    temp=58.0'C
    temp=59.0'C
    temp=60.0'C
HI, but this is fine for its size for the raspberry pi 3 not for the 4
