richcreedy
Re: Just received my RPi4b/4GB - no HDMI output!!!
Tue Jul 09, 2019 1:08 pm
ok no worries
aleixsr
Tue Oct 15, 2019 9:03 pm
same issue here, in my case only uncommenting this line worked:
config_hdmi_boost=4
Best Regards.
jimb757
Wed Oct 16, 2019 2:19 am
HawaiianPi's post worked for me.
Thanks,
Jim
mikecentola
Tue Oct 29, 2019 4:54 pm
Just wanted to share my results after struggling for a little bit. Have a samsung 4K TV that supports 60p but just couldn't get it into 60p mode.
Modified config.txt
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
hdmi_group=1
hdmi_mode=97
config_hdmi_boost=4
hdmi_enable_4k=1
hdmi_enable_4kp60=1
Rebooted, and set preferences in PIXEL. Rebooted one more time and all is well :)
txcdub
Thu Nov 07, 2019 2:40 am
Can someone explain what to do if you can't get any results from the tvservice -d edid dump process. Always "Nothing written!"
So frustrating. Been at this for hours and hours of reading posts trying things and no joy. And I can't even seem to get the data needed for serious troubleshooting.
haleruss
Sun Dec 01, 2019 3:15 am
I have the same problem
Saw this on NOOBS Raspbian download page:
Recovery
If your Raspberry Pi 4 will not boot, it is possible that the SPI EEPROM has become corrupted.
To check, remove the SD card, disconnect the device from power, then reconnect it. If the green LED does not flash, you will need to reprogram the EEPROM:
Download the bootloader
SHA-256: 444e0f68aa21d5b4e158259061de55738d36a1986e2ced14bb14d7af1a04881c
Extract it to an empty FAT-formatted SD card and insert it into your Raspberry Pi 4
Connect the power and wait for the green LED to flash quickly
I tried this, but nothing happens.
