Pi 4 with USB A to C cable
Posted: Sun Jun 30, 2019 9:10 pm
by murratw
Is anybody using a Pi 4 and powering it with an A to C cable. It is my understanding that if they are in spec they will have a 56k resistor and will force the device to negotiate for higher current over 500ma. I don't think the previous versions of the Pi ever negotiated for power as there were no data lines. I was wondering what would happen with this one.
I used the 2.5A official micro B power supply with a USB C adapter with the 56k resistor and the pi4 just pulled whatever it wanted.
Re: Pi 4 with USB A to C cable
Posted: Mon Jul 01, 2019 1:17 am
by W. H. Heydt
From comments I've seen, the Pi has a 10K resistor at the USB-C connector and that is the "negotiation" to get 3A.
Posted: Mon Jul 01, 2019 9:33 am
by Aardappeltaart
Yes, I tried to power and connect the RPI4 with just an USB cable, and a USB-micro <-> USB-C adapter from my laptop. It's working with Raspbian Lite. Haven't tried Kodi.
Like described here:
https://dev.webonomic.nl/4-ways-to-conn ... e-internet
Posted: Mon Jul 01, 2019 11:46 am
by emilfr
I run RPIs as home server, so wiill there be any problem in the long run to powered RPI4 with usb C converter?
I just don't like to have more unused micro USB, so if the converter would do the job especially for the long run, I'll get that instead.
Posted: Mon Jul 01, 2019 12:55 pm
by murratw
A legacy adapter to USB A has a 56k resistor which in theory tells the device to only draw 500ma. Wondering if that will limit what current the Pi4 will draw.
Posted: Mon Jul 01, 2019 9:23 pm
by Imperf3kt
It shouldn't.
