drgeoff
Re: Not all RPI 4's are equal?
Sun Jun 30, 2019 9:57 am
Aardappeltaart wrote:
Sun Jun 30, 2019 9:05 am
Thx, but that contradicts Eben Upton words “some thermal optimizations that are not installed by default on early production units.”
I can interpret "early production units" to encompass all RP4Bs produced before the optimisations are fully tested, deemed OK and used in production. If that point has not been reached, even as I type this, there is no contradiction.
Quis custodiet ipsos custodes?
lb
Sun Jun 30, 2019 10:09 am
I guess it's fair to say that all shipped units are "early production" so far.
Aardappeltaart
Sun Jun 30, 2019 10:32 am
You mean all Pi's are (created/shipped) equal now, but that will change in the future.
energyi
Mon Jul 01, 2019 12:41 am
0.357 watt difference is significant.
energyi
Aardappeltaart
Mon Jul 01, 2019 9:07 am
Yes, and IMHO the saving is much needed.
Thx to CNX-software for benching, Hias for giving details and thx to jamesh for demystifying the pleonasm spoken by the Great Wizard of Pi.
In memory of that, hereby I declare that the honorable title of Oracle of DelPi has been rewarded to Raspberry Pi Foundation's own Pithia Eben Upton for his ominous raving:
A riddle that can only be solved by the future!
Mon Jul 01, 2019 9:14 am
I suspect Eben may have been talking about different optimisations rather than the VLI firmware, but not sure.
Working in the Application's Team.
hardwaremack-orginal
Wed Jul 03, 2019 6:00 pm
my PI4B 1gig seemd slow, and was crashing alot.
this new PI4B 2gig, seems great!. 2g model seems to get much hotter, but works great!
Same PI 3A psu, Same SD Card, Same PI mHDMI cable.
I ran
rpi-update
yesterday. it updated, i rebooted.
I tried it again today and it tells me *** Your firmware is already up to date
1. I would assume rpi-update is what i should be running?
2. Should be able to run this many times with out bricking the thing correct? :-)
Thanks!
Wed Jul 03, 2019 8:22 pm
I ran
rpi-update
Thanks!
No, don't use rpi-update unless it has been recommended by a Pi engineer. It will have prototype or test code in it and may not fully work.
Use apt to update to the latest fully tested firmware.
Because we have been trying out some test software to try and fix some issues on some monitors, rpi-update has been suggsted in those cases. But if all works with the standard firmware, keep to that.
Wed Jul 03, 2019 8:26 pm
sudo apt-get update
sudo apt-get upgrade
Thanks James
Wed Jul 03, 2019 8:33 pm
sudo apt-get update
Thanks James
That would do it.
