ldr1
Raspberry Pi 4 Model B touchscreen
Sat Jun 29, 2019 11:59 am
Hello everyone,
I am completely new to the Raspberry Pi world, yesterday i decided to experiment with Raspberry and purchased the Raspberry Pi 4 Model B 4Gb. I want to make it as portable as possible and im looking for a touchscreen, what do you recommend?
I have looked at this https://thepihut.com/collections/raspbe ... ouchscreen do you recommend it for the Pi 4? is it just plug and play?
Thank you for the help
Re: Raspberry Pi 4 Model B touchscreen
Sat Jun 29, 2019 12:57 pm
Hello everyone,
The nearest you will get to plug'n'pray is the Raspbian Pi Official Touchscreen:
https://www.raspberrypi.org/products/ra ... h-display/
Thinking outside the box is better than burying your head in the sand...
Sat Jun 29, 2019 2:43 pm
Hello everyone,
The touch screen is NOT plug and play by any stretch of the imagination. If you want to risk blowing up a £60 screen and a £40 Raspberry just try it. If you disconnect the screen it won't restart without a full scale power cycle.
ldr1
Sat Jun 29, 2019 3:34 pm
Thank you for the quick reply.
What if I was to connect the touchscreen and just leave it at that"? Could I still connect the raspberry to a monitor using the hdmi connection? As if expanding monitor?
W. H. Heydt
Sat Jun 29, 2019 5:21 pm
From what I've read, yes. Look for the thread about dual-display testing (and not to be confused with the dual-HDMI capability of the Pi4B). I don't normally do that, though I suppose I should try it. When I want a bigger screen with my "portable" Pi rig, I don't supply power to the RPF 7" screen, but neither do I disconnect it.
All of this does raise another possibility for you which would be rather more "plug-n-play". The Pi4B has dual HDMI output. You could use a small (5" to 10") HDMI display and a larger, "desktop" display at the same time.
ldr1
Mon Jul 01, 2019 7:37 pm
hardwaremack-orginal
Mon Jul 01, 2019 9:16 pm
yeah the price and the resolution
is 2 negatives of the official Raspi screen.
the screen rotating upside down was annoying,
and the additional cost of the rear ( back ) is also annoying.
Yakbutter
Tue Aug 06, 2019 2:49 am
I bought the timeshare 10.1" touchscreen model b and am very confused plug almost any 3b into it and it runs fine.
But t I want to use the 4, ok bought 3 of th e m.
But the 4 won't even boot w I t plugged in.
This s screen is kind of wAcky. It requires usb connection for th e touch. A nd the Jimi connection f or video playbAck.
Plus it must be plugged into 20 of th e 40
Pins
I'm pretty e try s ure something about that glioblastoma connection as d s p.
J
mullcom
Wed Aug 21, 2019 6:56 am
Hello...
I am also intressted in to find touchscreen to Pi4 7" it a bit small and hope it come one that are a bit lager.
sine
Thu Dec 05, 2019 8:41 am
i want a touch screen for my RPI 4 as well , preferably 10 inch size , did not find one yet
Thu Dec 05, 2019 9:22 am
Imperf3kt
Fri Dec 06, 2019 3:04 am
Is that a RasPad without the casing?
55:55:44:44:4C
52:4C:52:42:41
Rose coloured glasses are difficult to see through.
