mikerr
Very simple OTG on pi4
Fri Jun 28, 2019 2:21 pm
I've found OTG is really simple and useful on the pi4 with new firmware.
Since the USB-C power port can now carry data, you can plug that into a USB port on your PC and access the Pi via a drive letter.
Image Image
Here's how:
1. Add a single line to config.txt :
dtoverlay=dwc2
2. Mount the boot partition as MSD on bootup:
crontab -e
@reboot sudo modprobe g_mass_storage file=/dev/mmcblk0p1 removeable=1
After a reboot the pi will appear as a drive letter under windows, with the boot partition being read/write.
Almost the same as if you'd removed the SD card and put it in a card reader on the PC,
with the difference that this is on the live running Pi.
I've already found this useful for changing wifi settings (drop a wpa_supplicant.conf file on boot), and for small file transfers (boot partition is now bigger in buster: 256MB with 200MB free space)
solar3000
Re: Very simple OTG on pi4
Fri Jun 28, 2019 6:37 pm
That is weird I got to try that.
Antikythera
thagrol
Fri Jun 28, 2019 9:04 pm
I'm surprised you've been sucessful with that though things may have changed with Buster.
On stretch (and earlier) if you make a change from one side of the mass storage gadget (e.g. from the USB host) the other side (raspbian) won't see it without unmounting and remounting the partition. Or a power cycle. Or disconnect/reconnect.
You're going to corrupt your data doing this.
This space unintentionally left blank.
lb
Sat Jun 29, 2019 2:16 am
Yeah, it's not safe to do this!
However, what is completely safe and also very useful is the g_ether module which allows you to let the OTG port act as a network device. It's probably not reliably to possible to power a Pi 4 plus peripherals from a typical PC USB port, but the Pi 4 on its own was fine, with the occasional low voltage warning.
Ebraheem Bambotia
Sat Jun 29, 2019 4:54 am
This is probably only useful for people who don't have an SD card reader on their PC or laptop and need to make changes in a hurry. Otherwise I don' tsee any point in risking data corruption as thagrol said
Sat Jun 29, 2019 5:33 am
If using the PoE Hat it could be useful ??
Retired disgracefully.....
thagrol
Sat Jun 29, 2019 10:15 am
Or power the 4B through the GPIO header.
thagrol
Sat Jun 29, 2019 10:19 am
It can be done safely, just not the way the OP suggests.
The trick is to only have the shared storage mounted on one side at a time.
Or use g_ether as suggested combined with an sftp client or run a samba server on the 4B.
Aardappeltaart
Sat Jun 29, 2019 5:06 pm
I got the RPI4 working and connected to the internet with just an USB cable from my laptop using Ethernet OTG.
Like described here:
https://dev.webonomic.nl/4-ways-to-conn ... e-internet
Dunno if my laptop delivers enough juice to do something fancy, but it's already sweating doing nothing:
61° idle.
