dialkey
"Click here..." is annoying
Thu Jun 27, 2019 6:48 pm
Hi, just installed Buster and the "Click here to open applications menu" never seems to go away. Do we really need these forever? Pretty sure even I can remember where to click after the first week. :)
klricks
Re: "Click here..." is annoying
Thu Jun 27, 2019 7:39 pm
Open autostart and remove or comment out point-rpi.
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
#point-rpi
Johnny_quattro
Sat Oct 19, 2019 3:55 pm
Thank you very much!
This has bugged me each and every time I've used remote access.
Since I have 11 Raspberry Pi units under my control, I've now been able to knock up quick SALT state to farm this change out to all Pi computers. For those interested in further knowledge, salt-master/salt-minion are very useful tools for managing computers.
I pass on my thanks for your nugget of useful info.
pcmanbob
Sun Oct 20, 2019 12:59 pm
#point-rpi
Tried the above edit and rebooted pi , still get the "Click here to open applications menu" on my pi4 running buster.
Paeryn
Sun Oct 20, 2019 1:15 pm
#point-rpi
Have you got a local config for lxsession? If so that is used rather than the global one in /etc
/home/pi/.config/lxsession/LXDE-pi/autostart
She who travels light — forgot something.
pcmanbob
Sun Oct 20, 2019 1:31 pm
No I have only made the following changes
install xscreensaver and used raspi-config to remove the Plymouth splash screen and enable VNC
I don't use raspbian with desktop very often I prefer the lite version , so its very much an out of the box install used for when I need to post images when helping others with desktop problems
klricks
Sun Oct 20, 2019 4:07 pm
#point-rpi
The OP is referring to the automatic positioning of the mouse cursor over the menu icon on each boot or login.
This makes the tool tip for the menu icon activate.
The 'mouseover' tool tip will still be functional unless you also disable all tool tips.
pcmanbob
Sun Oct 20, 2019 4:36 pm
My mistake miss understood what the change did.
Thanks for clearing it up.
Did ask once before about disabling tool tips on buster but no one ever came back with an answer.
Paeryn
Sun Oct 20, 2019 8:27 pm
From a quick look at the source code the tooltips are always added for the menu items (including the menu button itself) if there is a description present. It doesn't support the tooltips=0 setting that some other plugins do.
