jeffridder
Macbook USB C power adapter for RPi 4
Thu Jun 27, 2019 4:19 am
Can a Macbook USB C power adapter be used to power the Raspberry Pi 4? It seems like it would but just wanted to make sure before plugging on in.
jrodin
Re: Macbook USB C power adapter for RPi 4
Thu Jun 27, 2019 7:48 pm
I’ve tried both the 29W and 61W Apple USB C power adapters and unfortunately they don’t work with the Pi4.
jokinc
Thu Jun 27, 2019 9:21 pm
Macbook charguers also don't charge some other usb-c devices, i think they don't support 5v modes.
jeffridder
Thu Jun 27, 2019 10:42 pm
Thanks for the feedback. I thought USB C was supposed to be easier. :lol:
scorpia
Fri Jun 28, 2019 12:14 am
I suspect this might be a result of the pi only having a single cc pulldown resistor (there should be two) on the USB connector on the pi.
I have stared a discussion on this here https://www.raspberrypi.org/forums/view ... 3&t=243875 were there is also a technical write-up for those interested in the specifics.
Dygear
Fri Jun 28, 2019 3:27 am
Confirmed doesn't work with a Apple 87W USB-C Charger. But I did have a old iPad power brick laying around and a USB-Type A to USB Type-C connector on it and that works a treat!
richjc
Fri Jul 12, 2019 6:52 am
I am successfully powering my Raspi 4 with an old Macbook Air 45w magsafe power supply via an Apple magsafe to magsafe 2 adapter and an XCsource usb-c to magsafe 2 adapter, see:
https://www.amazon.com.au/dp/B07FP6JBBG ... TE_3p_dp_1
and
https://www.apple.com/au/shop/product/M ... -converter
Regards,
Richard
misterrobot
Tue Jul 30, 2019 6:44 am
What works though is to directly connect the pi to one of the Macbooks USB C ports.
As long as it is only for setting up the pi this should be a good workaround I guess
