alphixt
RPi4 - MicroSD card speed classes supported?
Tue Jun 25, 2019 8:50 pm
Anyone have any idea what exactly it can support when it comes to the bottleneck?
I reviewed some of the documentation and on page 23, all that was claimed (source: https://cdn.shopify.com/s/files/1/1560/ ... y_Pi_4.pdf)
The bandwidth bottleneck to the SD card has been lifted somewhat, the data rate has been doubled. This should allow faster boot-times and applications being more snappy in general.
My questions are:
  • What is the highest UHS Speed Class supported?
  • What is the highest Video Speed Class supported?
Any additional information and documentation is greatly appreciated!
I am not only trying to sell my friends on the new RPi 4 but trying to maximize my microSD card in terms of speed. I understand that sequential and random read/write speeds vary, however, I do not want to severely over-purchase on something the board physically can not support without throttling it down heavily. I don't mind minor throttling however.
Thank you for your time in advance,
Alphixt
Andyroo
Re: RPi4 - MicroSD card speed classes supported?
Tue Jun 25, 2019 11:47 pm
Welcome to the forum.
Just buy class 10 A1 rated card - anything less is not worth the savings.
Do not buy the A2 cards as the hardware in the SD card reader will not handle the electronics and reports of these being slower are t be found here and in other places.
I use SanDisk 16Gb as that’s a good balance between price and size for me BUT I normally run headless command line (i.e. Raspbian Lite) so the 16Gb is a bit OTT but plenty of space for wear levelling :D
Make sure you get them from a trusted source who will accept returns if you get issues.
Gavinmc42
Wed Jun 26, 2019 12:06 am
I also use the Sandisc 16GB A1, I find if you shop around a little they are currently the best value.
But for the Pi4?
The 4B4 is a decent Desktop replacement, for that purpose more storage will be needed..
USB boot is still in the works but USB3 caddy for SSD will be my preferred storage.
I expect we will get some more SDcard benchmarking results for the Pi4.
So far they are showing a 600+% speed increase in USB SSD read.
How that compares to an A1 uSD?
I'm dancing on Rainbows.
Andyroo
Wed Jun 26, 2019 12:10 am
You still need the SD card fir SSD boot :cry: but it knocks the socks of any SD card you can currently buy :lol:
Not in a hurry for a Pi 4 at the mo - the wallpaper has to come first :roll: (said through gritted teeth)
echmain
Wed Jun 26, 2019 12:13 am
It's important to have a nice background image.
Oh wait...do you mean actual paper for the walls?
alphixt
Wed Jun 26, 2019 12:15 am
Ya I personally was looking at either the Samsung MB-MC128GA/AM (128GB) or sell my soul and grab the SanDisk SDSQXPJ-128G-ANCM3 (128GB) if I could actually benefit from the read/write speeds.
  • Samsung MB-MC128GA/AM (128GB) UHS-I Read: 100MB/s, Write: 90MB/s (Sequential)
  • SanDisk SDSQXPJ-128G-ANCM3 (128GB) Read: 275 MB/s, Write: 100MB/s (Sequential)
My RPi is going to be a headless server as well. Aimed at hosting some of the projects I write that would service a few clients. The databases will not need to scale very large as of now- I just worry about read/write bottlenecks. Which is why I wanted to know the specifics when it came to what the RPi 4 would support.
HawaiianPi
Wed Jun 26, 2019 1:31 am
You don't want either of those. Operating systems do a lot of non-sequential I/O and need high random I/O performance (IOPS).
The SanDisk Ultra A1 cards are pretty affordable and should outperform either of your choices on a Raspberry Pi. For even higher IOPS a USB 3.0 SSD would be the best performer, and in sizes of 128GB+ should not cost much more than a good A1 rated micro SD (probably cheaper than either of your original choices).
What would be interesting to know is, will (or could) the Pi4 firmware be updated to support A2 performance class cards?
alphixt
Wed Jun 26, 2019 2:24 am
That's kind of what I am hinting at. All the documentation that I saw said that a bottleneck was slightly resolved. Still unsure what is and will be supported by the hardware. But you've help bring it to my attention that I should be looking more towards the 'A1' nomenclature (when it comes to SanDisk). I was aware of the sequential r/w not being the same as random r/w, but mistakenly believed a higher price-point card would inherently be better due to the r/w capabilities.
Thoughts on the SanDisk Ultra Plus (128GB)? Has the A1 badge and seems to be the "upgrade" to the Ultra.
Link: https://www.sandisk.com/home/memory-car ... rosd-400gb
Unfortunately, I am trying to lean away from having an external drive attached. I would like for only 2 cables extending from my RPi. Power and Ethernet. With plans on attaching the UPS Hat.
Gavinmc42
Wed Jun 26, 2019 3:35 am
I have some USB3 tiny 32GB Lexar USB sticks I use for booting 3B+.
Will they be faster on the Pi4's when USB boot is sorted?
Will USB sticks be an alternative to SSD's?
Never had a USB3 Pi before.
At some point uSD's are more expensive than USB and SSD.
If they are not faster you are only paying for size and less reliability?
alphixt
Wed Jun 26, 2019 3:48 am
For what it is worth, I plan on teaming the RPi4 with the UPS Hat.
There are times where I am doing some work away from home and not near an outlet to plug the RPi into. With the RPi4 being a testing environment, the plan is to just throw it into a backpack during these moments and tethering it to my phone for a connection to SSH into. The less things I have sticking out of it, the better.
Between the WiFi, BT, and UPS hat- I'll have nothing sticking out of it and at risk of damage (like a USB stick or external SSD might.)
Main point being:
My use case isn't for everyone, which is why I worded the question to retrieve information about the Micro SD Card speed classes that are supported (A1 & A2 now included) with the Raspberry Pi 4 in particular which could be helpful information to others.
pi3g
Authorised Reseller
Authorised Reseller
Thu Jul 11, 2019 7:05 pm
The Pi 4 doubles the data rate at which the microSD cards can be accessed by introducing a new memory controller for them. The old memory controller (Arasan) will now drive WiFi, and the memory controller which used to drive the WiFi is now free, for custom purposes (can be accessed using the GPIO if I rememember correctly)
picockpit.com - tools to make your life with the Pi a little bit easier
alphixt
Thu Jul 11, 2019 7:18 pm
I very much appreciate your insight! So from my understanding, as far as SanDisk cards go, A1 will still be supreme because the RPi 4 did not introduce additional functionality to support the A2 specification. Unfortunate news, but I am still very excited about the increased performance on such a small and cheaply priced board.
jdb
Thu Jul 11, 2019 7:37 pm
The majority of USB2.0 pendrives used to have performance roughly on par with mediocre SD cards - they had flash controllers that were not optimised for random read/random write performance. USB3.0 pendrives are generally "better" for some value of better - I would recommend getting ones that support UAS as well as USB Mass Storage, or ones that have very high sequential read speeds as this usually means they interleave reads from multiple flash chips.
Rockets are loud.
https://astro-pi.org
chipace
Thu Jul 11, 2019 10:16 pm
If SD Express cards become more common (and cheaper), maybe the RPi4B+ could use that instead of regular SD. Is there an unused PCIe lane on the RPi4 SOC?
W. H. Heydt
Thu Jul 11, 2019 11:46 pm
There is only one PCIe lane, and that lane is dedicated to the USB hub.
HawaiianPi
Fri Jul 12, 2019 7:47 am
USB thumb/pen/stick drives are optimised for sequential read/write, and as such, are not the best choice for an OS drive, and certainly not a substitute for an SSD (which has very high IOPS).
I would expect most USB 3.0 stick drives to perform worse than an A1 rated SD card. SanDisk used to have a couple of models with reasonably high IOPS, but I'm pretty sure they are discontinued now, and they were quite expensive anyway.
Best bang for the buck in performance is an A1 rated micro SD card. If your storage needs are moderate, that's what I would recommend. If you need 128GB or more of storage capacity, then SSD becomes a viable option (because at those sizes they'll be roughly the same price, or possibly even cheaper than a comparable size A1 SD card).
With the old Pi 3B(+) modes there were compatibility issues when trying to boot from some USB mass storage devices, but most worked fine when booting from SD card and just using the USB drive for storage. Hopefully, with the much larger space available in the Pi4 EPROM, the boot loader will be more compatible and we won't have to deal with such issues (something to keep in mind, though).
RaTTuS
Contact: Twitter YouTube
Fri Jul 12, 2019 8:04 am
cough cough
http://mloduchowski.com/en/blog/raspber ... i-express/
from
https://hackaday.com/2019/07/10/giving- ... i-express/
Covfefe
Gavinmc42
Fri Jul 12, 2019 8:23 am
Looks like there has been a flash chip price drop recently.
Got a Sandisk 64GB A1 uSD and some 32GB USB 3.1 Ultra fit sticks at good prices today.
Spent about 3 times the cost of a Pi4 on memory this week.
Just got yelled at by the finance manager when the credit card bills got spotted :oops:
Might have to use loose change from now on for a while ;)
The 128GB was not too badly priced but I value my life a little bit :lol:
arminf82
Wed Sep 18, 2019 8:17 am
I use the SanDisk Extreme Class 10, U3, V30, A1 and it is a huge improvement to my old SanDisk Ultras.
Which card would be even faster than my SanDisk Extreme A1?
Moon Pi
Wobbo
Mon Mar 02, 2020 6:54 pm
I find SD cards very confusing. This way I see all classes in which I thought it was invented by different companies. I just thought the fastest I could find for a reasonable price. Adata SDXC, Speed ​​10, UHS-2, V90 and Speed ​​up to 275mb / s. But ... Did not work well!
So much info on the all products and types:
Types: SD, SD HC, SD XC, SD UC
Speed ​​Class (in round circle icon O): 2-4-6-10
UHS-I speed (in a icon U): 1-3 or UHS-II: 3 or UHS-III: 3
Video speed class: V6-V10-V30-V60-V90
Application Performance Class: AI-AII
Confusing? lol So ... If you understand a little what those numbers mean, you still don't know how fast your SD can go! You can see what the maximum speed can do. Fortunately you see the speed on the package ... But then you don't know everything yet. It says: Speed ​​mb / s *. That means the read speed is not the write speed. You can almost never see if the packaging is what the write speed is! Both are important with a Raspberry Pi. Confusing?
That the Adata SDXC is not working properly has to do with V90 that requires UHS-2. It appears that the hardware is different from V30 but is compatible with all SDs.
That does not mean that you know how fast your SD card will be. All SD card info is only about the input and not the output. For example, if there is 100mb / s * it means the asterisk * it is about the writing speed. The writing time is always lower than the reading speed. This can be a big difference. It is good to search what the writing speed is. Sometimes it does not state the package!
A Raspberry Pi 3 and 4 cannot have UHS 2 and 3. V60 and V90 require UHS 2 or 3.
After long Google scrolling it comes down to having an SD Class 10, UHS 3, V30 and A2. Now I don't know how much Rasberry uses UHS-I, V30 and A2.
At this time this looks like the best SD card:
Sandisk Extreme Pro 64GB microSDXC UHS-I
